New project installed
Old Jun 14, 2006 | 05:25 PM
sykou's Avatar
Originally Posted by mitsuozboi
I kinda read somewhere that on our car, drilled and slotted rotors were bad because they did not allow the brakes to build up enouph heat. Slotted were better but drilled/slotted was overkill. I dont quite remember where I read it but That comes to mind. any ideas on that?
They look good.
I haven't read anything about this but from experience i can tell you that it is a bit harder to stop when the rotors/pads are cold as compared to stock. Takes maybe a few stops to heat the pads up. Oh BTW my setup is stock calipers/Axxis Deluxe pads/RRM Slotted Rotors. I would assume that the drilled/slotted combination would make it even harder to stop when cold.
Oh and on the subject on brake fade... I've never had brake fade EVER even after doing about 20 minutes of repititive hard braking and accelerating.
