so this is me
Old Jun 20, 2006 | 08:18 PM
  #31
rpm_ruffryders's Avatar
i know that it comes in other cars..."this particular one" came from a stratus. oh, and stroked it will be...but i plan on thinking outside the box...just like the 2.4L in an OZ...I want other "first time ever" mods
Old Jun 20, 2006 | 08:37 PM
  #32
TeamAccolade's Avatar
i was saying destroke it to a 2.1lt
Old Jun 21, 2006 | 08:03 AM
  #33
phil_'s Avatar
how did you get the passenger side engine mount to work.
I was seriously thinking about this swap and noticed the G94 pass. side engine mount was different than the g64
pics of the mounts would be EXTREMELY appreciated
Old Jun 21, 2006 | 12:16 PM
  #34
Kid Lancer 7's Avatar
what makes this swap worth the $ vs. just building on a 4g94? i understand you said 20 hp 20 tourqe.... but can you give us a bit more details? is that a v6??(stratus is a big car) is there room to boost?
Old Jun 21, 2006 | 12:58 PM
  #35
imajinmyfx's Avatar
looks real good!.. is that an accolade kit?
Old Jun 21, 2006 | 03:19 PM
  #36
Tony_rage's Avatar
Awesome car!!! any new pics??
Old Jun 21, 2006 | 05:59 PM
  #37
actually...its 30HP gain on the engine swap alone. as far as cost effectiveness...WHERE DO I BEGIN?!? the engine is CHEAP to buy ($450), thats a little over the price of a header that only gives you, what, like 18hp?...on top of that...you can find ALOT more companies support the aftermarket mods for the G64 than the G94...so if you plan on "building" a G94...ur gonna run outta options REALLY fast and no, it's not a v6...the 2.4L is a 4 banger (the SE and SXT STratus come with the 4G64-yea, I know). Not ot mention that with the G64 you can use a host of parts from the 1st and 2nd Gen Eclipse GST/X!!! I am currently designing a turbo set up using the 2nd Gen GST and all for less than $700!!! yea, a turbo for less than a piggy back ecu and a header!!! the possibilties almost seem endless. Not to mention the fact that you can mate a 4G64 bottom with the 4G63 head!!! (another plan of mine)
I'll post pis of the mounts when i get my camera back.
as for the kit...its from extreme dimensions http://www.extremedimensions.com (sponsor)
Old Jun 21, 2006 | 07:02 PM
  #38
mitsuozboi's Avatar
nice. the combos with the engine should be a topic of a thread you should make when you get more info. sounds like it would be a decent swap especially with some know how of what works with it.
Old Jun 21, 2006 | 09:02 PM
  #39
phil_'s Avatar
yea as said the real gains come with this swap once you get the G63 head on there, it can indeed be done (check club3gforums.com) - however that said, it is alot of work
also any manifold made for the dsm/evo should bolt right up
well worth while swap IMO
Old Jun 21, 2006 | 09:27 PM
  #40
GPTourer's Avatar
Yes, you can bolt on an Evo head, but it seems like a very roundaboutway of doing it. The block has to be pulled and machined some to fit the Evo head. You are also going to want to change out the internals if you are going to run any kind of siginificant boost, other wise it would be a waste, IMO. So why go to the trouble of installing a 2.4, just to pull it and build and swap heads? Why not just swap in a EVO 4G63T to begin with? I understand the allure of having a bigger displacement turbo engine, but it would cost more to go about it this way.
However, doing a budget turbo kit on a 2.4L with around 7psi nets around 220-240whp, so that swap path makes perfect sense if that is the end goal.
Old Jun 22, 2006 | 04:59 AM
  #41
the reason why im asking is because before i go on with building this 4g94... i could continue to part out some stuff and do this motor swap and do some 1st time research along with you. I got some brand new forged pistons already (10 compression though.....maybe a different head gasket will set me up for a turbo in the future.) Im seriously thinking about this swap (need a 2nd job for this lolol... and i might just take my 4g94 turbo off this weekend!). if the hp was like another 50hp it would be a no brainer to me.. but judging on what u said even though its ony 30hp more... this seems better than steroiding a 4g94 basicly the engine swap alone ='s i can **** off ralliarts hit me up on aim s/n "doncorleyone"
Old Jun 22, 2006 | 05:07 AM
  #42
Assassin's Avatar
Now that's a nice lancer.
Old Jun 22, 2006 | 02:55 PM
  #43
lancerman360's Avatar
I thought the 4g64 was the same engine in the 4 banger eclipses? I have a buddy that had one (wrecked now). We raced a few times just for the heck of it ans I never beat his completly stock automatic eclipse.
Old Jun 22, 2006 | 03:19 PM
  #44
so i guess i would be able to complete an automatic setup with this??? mann i wanna do some research soooo bad but i dunno where to start!
Old Jun 22, 2006 | 04:48 PM
  #45
GPTourer's Avatar
It came in a whole bunch of cars. Galants, Eclipses, Outlanders, Strati/Stratuses and Sebrings.
