Check Out My Black Reflectors
Old Jun 29, 2006 | 07:48 AM
mscc04's Avatar
Finally finished painting my stock amber reflectors black today. I used Krylon Fusion Gloss Black, Rustoleum Reflective Paint (waste of $7), and Clear Coat. Matches car beautifully. Sorry my car needs to be washed.
Picture of Just one of the Reflectors
Pictures of Reflectors on the Car
Attached Thumbnails Check Out My Black Reflectors-blackreflector.jpg   Check Out My Black Reflectors-sidereflectorsoncar1.jpg   Check Out My Black Reflectors-sidereflectorsoncar2.jpg
Old Jun 29, 2006 | 08:48 AM
Tony_rage's Avatar
it does match pretty good... good job!
Old Jun 29, 2006 | 08:51 AM
Melaz425's Avatar
The look pretty good. What kind of wheels are those? They look like knock off evoVIII enkei's.
Old Jun 29, 2006 | 09:09 AM
mscc04's Avatar
The rims are 17x7.5 Sport Edition F2 Rims from TireRack.com. I wasn't really trying to get EVO knock off rims but it definitely looks that way.
Old Jun 29, 2006 | 10:15 AM
ThunderOZ's Avatar
matches perfectly to me...
Old Jun 29, 2006 | 10:56 AM
Tony_rage's Avatar
How did you take the reflectors out???... i want to do that today.
Old Jun 29, 2006 | 10:57 AM
Blacksheepdj's Avatar
It sucks.
Driver side, you just pull back the wheel liner and unscrew them.
Passenger side, you crush your hand between the fender and the squirter bottle to get the **** out...
Old Jun 29, 2006 | 11:02 AM
Tony_rage's Avatar
Thanks!!! good deal!!!
Old Jun 29, 2006 | 11:11 AM
mscc04's Avatar
The easiest way to get out the driver's side reflector is to take out the headlight. Three bolts 10mm, undo headlight plug, the plug above turn signal, take out turn signal bulb, and wiggle the headlight out (just take your time and be careful removing the headlight). The screws are super easy to undo from there on. The passenger side is the horrible side. You can take out the headlight on that side as well (just to make everything easier to reach) but to take out the screws you will have to unbolt the windshield washer fluid container. One bolt 12mm and one nut 12mm. The bolt you can easily remove once the headlight is removed. The nut is a pain and to do this you need to turn your wheel so you have access to the splash guard. I removed the bolt that connects the bumper to the fender and popped off the black rivet just below it (i think it is actually called something else but that's all I could come up with). I then pulled back the splash guard and pushed on the inside of it so it would pop out more so I could reach a hex wrench to take the nut off. It was a major pain but I got it off and then I could reach the screws. The screws are also a little struggle to get out but it can be done. Then you are set. Just make sure the paint is completely dry before you put it back on since you'll have to handle the reflector a fair amount. Best of Luck!
Old Jun 29, 2006 | 11:22 AM
Tony_rage's Avatar
damn.. too much work just for that..lol
Old Jun 29, 2006 | 11:29 AM
mscc04's Avatar
Just take off the passenger headlight and see if you want to mess with it. The driver's side is easy.
Old Jun 29, 2006 | 11:31 AM
Tony_rage's Avatar
yeah, i pmd you back.. i decided to wait until i black out my headlights.. i was going to do that today.. but i dont have time anymore... next week!
Old Jun 29, 2006 | 11:37 AM
mscc04's Avatar
Probably a good idea. Just don't get caught up in doing too many things all at once. I used the same paint (Kyrlon Fusion Gloss Black) when I blacked out my headlights. Good luck with both projects! And if you need any help let me know.
Old Jun 29, 2006 | 12:31 PM
sykou's Avatar
I just smoked my reflectors not too long ago and the way i did it was to remove only one of the washer resoivoir bolts. The one closest to the front. Then kinda push it towards the passanger side wheel and i had barely enough clearance to fit a screwdriver in there.
Old Jun 29, 2006 | 05:03 PM
Melaz425's Avatar
I just took my front bumper off to install the cf reflectors. It took a little longer but saved me alot of bloody nuckles and frustration
