19" and 20" rims on the lancer
http://www.miata.net/garage/tirecalc.html
there you can figure out what youd need. To run the same size ratio you would need a tire in a 215/25/20. a 25 series tire is more or less a rubber band and i dont think they even make them, i sure as hell couldnt find them on tirerack.
^but how wide are his 22's? Its a precentage thing. a 22x8.5 with 255-25-22 tires would actually have more distance between the wheel and the ground as opposed to a 20x7.5 with a 215-25-20 will be smaller.
thats why you see some cars like supras with wider rear tires that have a smaller tire thickness # but are the same size as the front narrower tire. Did that make sense? its hard to explain on my keyboard.
kinda like when your mom asks why the keyboard is sticky? lol
