My Evo Mini=) SLow build..
i put a lot of clear coat (cant tell with ****ty camera)
but i just wipe everything off with my hand
i just shot adhesive promoter , then primer(wet sand ), paint , then reg car clear!!!
u could actualy see the gloss if u look into the cluster area in my pic!!
in total it cost me about 15 bux?!
Well I installed the tailights the turn signals worked fine. I went to go pick up a friend and they said that my right reverse light wasn't working. Then a week later when I turned on my right signal it started clicking real fast and didn't come on at all. I know its the actual light that doesn't work because I changed the bulbs out with the stock lights and it still didn't work. I might buy some jdm black tailights off of ebay. I'm terrified to order something else from RRM it might blow up my car.
Well I installed the tailights the turn signals worked fine. I went to go pick up a friend and they said that my right reverse light wasn't working. Then a week later when I truned on my right signal it started clicking real fast and didn't come on at all. I know its the actual light that doesn't work because I changed the bulbs out with the stock lights and it still didn't work. I might buy some jdm black tailights off of ebay. I'm terrified to order something else from RRM it might blow up my car.
Popostrus I say!! I'll post the picks when I get them fixed hopefully soon. I already feel broke=)
Forget the strut bars and the interior for now, get a sway bar with autocross perches from RoadRace. You'll enjoy the car so much more than you would with any cosmetic change for the same price.
Will do. Hey would you guys suggest taking out the wiring harness for my stock lights and putting them on my aftermarket lights? Or can I use any harness?
