Will this work?
Old Jul 29, 2003 | 07:25 PM
pumpdog720's Avatar
Will this work?
Wheels 17"x7" with 4x100 bolt patter and 42mm offset on a ES?
I really don't know anything about wheels and tires. That's my weakness. I thought the 4 in the 4x100 meant 4 lug nuts but the wheels they show online have 5 holes but says 4x100.
Old Jul 29, 2003 | 07:58 PM
majestic lancer's Avatar
im not sure if the oz lancer has the same wheel specs as the es lancer.. but i have the oz and the wheels im going to get are 17x7, 4x114.3, with a 40mm offset. pearlwhiteoz just informed me that regular lancer offset is between 40-45 to keep from rubbing. hope i helped somehow..
Old Jul 29, 2003 | 08:00 PM
KTRLancer02's Avatar
well look for your wheels somewhere else to make sure that they are actually 4 lug. Just type the wheels in on ebay and look for them, if not a search engine, always be safe then sorry. I dont see you have a problem with these wheels with 42 offset. YOu can always ask other ES owners.
Old Jul 29, 2003 | 08:08 PM
pumpdog720's Avatar
I will actually probably be going to Pep Boys ang get my wheels there. I just found these online, and they said 4x100 but showed a wheel with 5 lug. I guess the picture is wrong. It just got me confused, I'm not that good with tires/wheels as I said. But the guys at Pep Boys should help me out! Thanks!
Old Jul 29, 2003 | 08:14 PM
Good luck, make sure you post pics of them when you get them on. Id like to see what you picked out.
Old Jul 29, 2003 | 10:47 PM
RollerPyro's Avatar
Be aware that somtimes the same style of wheel has different lug patterns. I e-mailed tirerack.com about one of their wheels once because they said it fit LANCER ES but the pic showed 5 lugs. They said they had the same wheel with a 4 lug pattern.
