Boosted 08 Hotness
Old Mar 25, 2008 | 03:14 AM
  #46
Puerto_reCOn's Avatar
nice. replace the red couplers with black ones and that thing would be on fire. nice one rrm
Old Mar 25, 2008 | 05:32 AM
  #47
ModernRacer's Avatar
ok so what are you running for Engine managment? did you get rid of the unreliable 5th injector?, what size turbo? do you have a Dyno sheet for the numbers?
Old Mar 25, 2008 | 09:55 AM
  #48
Brian@RRM's Avatar
we made our own engine managment for the kit
the 5th injector is very reliable if hooked up correct. and your gas milege is maintained under normal driving conditions and it is perfect for low boost applications.
16g turbo.
Old Mar 25, 2008 | 10:17 AM
  #49
Brian@RRM's Avatar
the red run is the turbo, the other run is wil an intake pulley and i dont remember what else.
Old Mar 25, 2008 | 11:46 AM
  #50
Evolution Racer's Avatar
Sexy... now this was running 7.5 pounds right? Is it safe to run 10 on the kit?
Old Mar 25, 2008 | 12:23 PM
  #51
TougeOZ_04's Avatar
price looking the same as the 04+?
Old Mar 25, 2008 | 12:50 PM
  #52
so by saying you "made" it yourself, meaning Split second built it for you once again, and not to bash, but why wouldnt you design a kit using bigger injectors instead of the 5 th injector, is it a cost issue?, i have seen all to many times thoes 5th injectors fail during boost leaving behind a mess of problems. I dunno seems like you just adapted a 2.0l kit for the new style Lancer's correct me if i am wrong
Old Mar 25, 2008 | 04:06 PM
  #53
Brian@RRM's Avatar
the point of the 5th injector, as i stated before is both reliable and saves on gas when u are not on the car, as well as a bit cheaper so that the kit is afforable for the public.
the only time i have seen the injector fail is if the box is hooked up wrong, other than that it proves good power and gas milege.
Old Mar 25, 2008 | 04:36 PM
  #54
08Lancer89's Avatar
sweet cant beat that combo!
