evo IX back seat?
Old Apr 11, 2008 | 10:30 PM
Domanni82's Avatar
evo IX back seat?
Hia guys, i did some searchin' and couldn't find much. I was wonderin' if the evo 9 back seat will fit in my 03 OZ. Anyone know anything?
Old Apr 12, 2008 | 07:10 AM
SLVROZ_03's Avatar
Yes, with a slight bracket modification.
Old Apr 12, 2008 | 10:53 AM
Domanni82's Avatar
how slight? LOL
Old Apr 12, 2008 | 03:56 PM
Lumpy's Avatar
Welding required, not much but some.
Old Apr 12, 2008 | 09:35 PM
SLVROZ_03's Avatar
No one said anything about welding before? Of course I've never done this...it's only by what others have said.
Old Apr 12, 2008 | 09:45 PM
TheShortBus's Avatar
^^ yeah ive never herd that either
Old Apr 12, 2008 | 09:59 PM
Lumpy's Avatar
I could have swarn that someone on here had said that they had to weld the brackets a little to make it work. I could also be wrong though because I've never done it either, so I'll shut up now.
Old Apr 12, 2008 | 10:25 PM
Fuze49's Avatar
Doing some welding you can make it work.
Old Apr 13, 2008 | 07:21 AM
SLVROZ_03's Avatar
Some care to expand on this "welding" I've never heard of doing on this swap before?
Old Apr 13, 2008 | 10:23 PM
Domanni82's Avatar
yea... um...welding.....um....huh?
Old Apr 13, 2008 | 10:47 PM
Fuze49's Avatar
There's a write up some how in the how to's. I know some one has done it before and it does require welding of brackets and what not to widen the seat platform because the Evo seats are wider than the Lanccer's.
Old May 9, 2008 | 02:47 AM
Juan Martinez's Avatar
I have done this swap on my es. The welding is not required if you have the seats that don't fold down. The backing slides right down on the hooks. You do have to bend some of the brackets on the seats at the bottom to fit it in. For the bottom, you have to bend some brackets also and you have to get a set of evo clips for where you clip and unclip the seat to lift up on. I should do a write up. They do fit, but there is a slight gap that I still haven't figured out how to fill. I just placed a towel on the bottom to push it up and you really can't tell.
Old May 9, 2008 | 02:34 PM
atilla's Avatar
as i've said in other threads about seats: it's not that hard. i helped my friend put evo seats in his OZ and there was no welding required.
as for that gap: make sure the seats are hooking into the little brackets at the top of the body behind the seats and that should them in place. then cut through the foam and put a piece of aluminum through the back of the seat; thread it through the metal bars inside the foam. put two carriage bolts into the aluminum and thread all that BS through a piece of MDF that fits over the opening where you can get to the trunk. if you already have something there just drill through that and secure the carriage bolts on the other side (inside the trunk).
David Buschur
10
Sep 5, 2011 09:57 AM
AJR-Coco
Northwest Region
Mar 6, 2011 06:44 PM
straightevo8
Oct 19, 2010 03:52 PM
DELANCER
Feb 8, 2007 06:15 PM
e.n.d.
Jul 17, 2005 09:13 PM
