What will work
Old Aug 7, 2003 | 10:08 AM
2hot4u's Avatar
What will work
I need some help with the size of 18's i need. i am not really good with the sizes of 18's cuz all i have ever bought is 17's but now i want bigger! I need to know the best size to fit on my car. it has a 1.3 eibach drop. what is the smallest tire size that i should use? what offset should i use? Last i dont want it to scrub sooooo..... give me some much needed info. thanks
Old Aug 7, 2003 | 10:24 AM
JWERNER24's Avatar
In Timeout
probably in the wrong forum for wheel/tire help dude....
Old Aug 7, 2003 | 11:38 AM
Babblingsponge's Avatar
I would say you should get a 18x7.5 with a 40mm offset and then get 215/35/18 or similar...at the very least you should use a 35 series tire. Check out my wheels...they are 18x7.5 with a 40mm offset and 215/35/18 wheels
https://www.evolutionm.net/forums/sh...threadid=33803
Old Aug 7, 2003 | 08:25 PM
ZapcoLancer's Avatar
Okay, I have this setup and do not rub. Eibach kit with 215/35/18, and do not rub at all. Looks hella tight too I might add
Old Aug 7, 2003 | 08:28 PM
2hot4u's Avatar
what offset?
Old Aug 7, 2003 | 08:31 PM
40mm..
