Check this out, I wana do it! But How...
Old Aug 12, 2003 | 09:45 AM
Kelspar01's Avatar
Ok i debaged my car, as in took my ES off, but i left the lancer and but now i want to paint that and the front part of the grill that is silver, i want to paint them blue like my trim. Anyone know what kinda of paint i will need to use? thanks lots!
Old Aug 12, 2003 | 09:54 AM
RobertK's Avatar
t38 is the color code.
just airbrush it I would think.
or use some blue tape for the
Old Aug 12, 2003 | 01:23 PM
FaLLeNAn9eL's Avatar
parts:
wrench (remove grill from hood)
screw driver (remove fins from grill)
white tape (to cover areas u dont want to paint)
paint
Removing Grill:
behind the grill there should be 4-6 nuts holding the grill in place. 2 of them are covered with a black rubber cap. after removing the nuts u then squeeze the yellow tips so that the grill will come off the hood.
Removing the Fins:
There are 6 screws on each fin. unscrew those and the fins should come right off.
Old Aug 12, 2003 | 01:40 PM
sharpie's Avatar
What type of sanding should be done to the grill to ensure the paint sticks?
I had taken off my grill to paint it, and I did a couple test areas to see how the spray paint would stick, and it came off too easily.
Advice please.
Old Aug 12, 2003 | 05:15 PM
porkchop13's Avatar
I painted the grill inserts, i just cleaned them real well and put 8 coats of paint and about 5 of clear coat.
