ClixT's Build Thread (56k warning!!)
Old Aug 27, 2009 | 11:25 PM
  #121
ClixT's Avatar
yup he charged me. but its gonna be cheaper if your gonna get the combo.
Old Aug 28, 2009 | 12:41 AM
  #122
ThunderOZ's Avatar
Tools? You need like 2 sockets and some wrenches...
Old Aug 28, 2009 | 08:55 AM
  #123
ClixT's Avatar
the one you need to compress the piston. its easier if you have it.
Old Aug 28, 2009 | 09:49 AM
  #124
link62's Avatar
you could use a C clamp to do it lol speaking of brakes mine are basicly out now they are sqeaking a lot so got to replace the pads today
Old Aug 28, 2009 | 10:35 AM
  #125
ClixT's Avatar
good man. safety first.
Old Aug 28, 2009 | 12:00 PM
  #126
ThunderOZ's Avatar
I've always just used a flathead screw driver...
Old Sep 3, 2009 | 10:48 AM
  #127
ClixT's Avatar
update:
pulley installed. took me awhile to install it properly.. (so stupid lol)
i say i gained like 1-2 hp, thats it. you can barely feel it.
Old Nov 19, 2009 | 11:48 AM
  #128
ClixT's Avatar
update:
painted the door handles. i actually messed it up...
Old Nov 22, 2009 | 01:31 PM
  #129
justin.AZ's Avatar
Clix,
Regarding compressing the piston, you do not need any tools to do it. Simply take the old pad and put it against the piston then press it and the piston will go back in its place so it will not hit the pad when closing. I changed my pads with the directions on the how to forum and it was very easy to do, required only a socket wrench and a 14mm socket.
BTW, Very Nice looking Lancer.
Justin
Old Nov 22, 2009 | 04:31 PM
  #130
02-Lancer-Es's Avatar
Now paint the mirrors!
Old Nov 22, 2009 | 08:42 PM
  #131
ClixT's Avatar
Originally Posted by justin.AZ
Clix,
Justin
i got it long time ago. thnx for the tip though
and thnx again. =)
also, im planing to paint my rims bronze (duplicolor). should i?
Old Mar 13, 2011 | 07:35 PM
  #132
ClixT's Avatar
Dang its been awhile.. lol
Ayt velocity stacked evo tb installed:
What I did is I bought some tiny crimp-on connectors and plugged it into the evo tps connector. Then I spliced the other end to the lancer harness. Hey it works lol
Things I learned from the install:
Make sure the vacuum hoses are super tight or else you'll have some vac leaks.
Switch the lancer IAC to be safe. (unless you're sure the evo IAC is working)
Last but not least, buy an evo tb with the TPS harness! lol
Things I NEED to watch for:
When I got the the evo tb, the tps is sensor is broken into pieces. I superglued and its working awesome.. for now.
The wires that I spliced..
Old Mar 13, 2011 | 07:42 PM
  #133
link62's Avatar
dude u should of told me u needed a harness lol i have like 4 extras that i cut off a bunch of 1 and 2gs when i did mine
Old Mar 13, 2011 | 08:24 PM
  #134
slatermvp's Avatar
How is it performing?? where do you feel the biggest difference lower rpms/higher rpms??
Old Mar 13, 2011 | 09:07 PM
  #135
ClixT's Avatar
Dude I'll get one from you then! =3 hehe
It accelerates a lot quicker than before and the response is awesome! =)
What I need to do now is to install my 501 maf and have a tune, which won't happen anytime soon..(Im soo broke!! lol)
