18x9.5 on a regular lancer cant be done?
looks off imo, but thats just me.. i dont think i can drive with the tires that close to the fenders... i like to drive my cars aggressive at times, and that will definitly not let me do that haha.
i guess so. the tires are 225/40/18. rims 18x9.5. +35 drop is megan coils. called around and searched around for a tire shop that would do it without scratching the sh*t out of my rims. plus the guy that put them on took real good care. and i used spacers in the front and soon to have spacers in the rear. playing around with the coils was the hard part hahah trying to get as low as possible but not scrap or rub anywhere. also adjusting the front camber to where it barely fits. i have -2.whatever in the rear and -3 in the front. and yes ive rolled.
Trust me, im lowered with TEINS, I have Enkei RPF1 18x8.5 30 offset and they rub like hell with those 245 tires, needed to roll the rear fenders.
The problem is not the wide of the rim, is the offset you use.
I choose 8.5 rim because I want the tire to be more wide that the rim, I like that look. But you can easy fit a 9.5 like this guy, the only thing is that you never gonna fit a wider tire. You need to look for the perfect wide , tire, offset combination.
If you want a look at my setup look here.
https://www.evolutionm.net/forums/la...ot-teaser.html
A 255 will fit a 9.5" wide rim as I had 255/40/18's on my previous car with 8" wide rims.
The thing you've got to worry about, for p00shy at least, is at 255 his sidewall is going to contact the fender. Good thinkin' on stretching those tires onto those rims bro, the angle of the sidewall is likely saving your ***.
BTW: This is LogicGTS from 9gL.
