US Lancer Original Grill Painting Question...
I've seen a couple people paint there ugly chromey grill to make the color of their car, I would like to do this, any1 have a guide?
Sand down the chrome, and paint? Lemme know thanks...
Example: (Iamkar33m's car)
I just took mine off and took the horizontal grill pieces out. Taped off the mitsu diamond to keep chrome(if you like) and spraypainted it. Oh ya! I cleaned it real good too. Wear gloves if you have them so you don't leave fingerprints. I didn't sand down or anything first like that. I used high temp low gloss black engine enamel.
Here's a pic of mine:
scuff the chrome with steel whool and use paint thinner to clean off the residue then primer with auto primer and then paint the color and finally the clear. Use about 2 coats of color and 4 coats of clear.
Good info, rbbcustom, your way you would end with a Shiny Glossy effect right? pumpdog's way would be a lowgloss ( due to the spray paint ). I want pumpdog's look, but Im worried about paint chip/etc cause he spray painted right ontop of the chrome and thats it....
Hmm so if I went the spray can way as pumpdog did, I can still scuff the chrome with steel whool and it would come out fine right? That would be the best way to achieve that look?
Originally posted by kromix
ok and that engine paint u said stayed on fine on top of the chrome? no peeling etc? and the horizontal pieces, how do you take that out? does it just pop off?
the flat paints tend to stick alot better than glossy paint but if you do decide to scuff it use primer to cover the scratch lines. I used the paint left over from the RMR lip the bodyshop gave it to me.
Originally posted by rbbcustom
this the finished product. If you dont scuff the chrome It will come off if you take it to the car wash. I learned the hard way.
Originally posted by SICKdimension
for that thunder gray car, is there a certain spray paint color/brand that matches that i could pick up at an auto parts store?
But if you can find the right matching spray paint go for it. Some how Kareem found the right matching spray for the silver which he did his eyelids with and maybe the grill too.
