some problem with my headlight
Old Jun 12, 2004 | 09:23 PM
initialD's Avatar
when I install the XNEON bulb, every thing is perfect, but after I turned the right bulb for a while, the right one does not work. and both side day time lights do not work. but left side head light is working. what is the problem?? can I repair it by myself or need to go to a garage??thanx
Old Jun 13, 2004 | 12:03 AM
Panther893's Avatar
ur bulb is just prolly out happened to me....
Old Jun 13, 2004 | 12:22 AM
Genki's Avatar
Is it a HID bulb or regular bulb?
Old Jun 13, 2004 | 03:07 AM
ghostrider's Avatar
Sounds like the case. Either that or you didn't fasten the bulbs on tightly enough when you installed the new ones. More than likely though, they just burned out.
Old Jun 13, 2004 | 05:09 AM
initialD's Avatar
it is tightly enough. I turn the right side bulb, why both side daytime lights do not work??
Old Jun 13, 2004 | 08:35 AM
ghostrider's Avatar
Did you try putting the stock headlight bulbs back in to see if the side markers (that's what I'm assuming you mean by daytime lights) cut back on? That and maybe try swapping those bulbs (side markers) with the side turnsignal bulbs to see if it's the sidemarker bulbs that went out.
If none of the above work, then maybe you blew a fuse (check the manual to see which one).
