Gauge cluster
Old Apr 8, 2006 | 01:08 AM
brian38662's Avatar
I know it's been a long time since this thread was posted, but I wanted to ask you a question about the EVO gauges fitting into the Oz Lancer. I believe you said they were swappable? Do you know if it's just a plug in type swap or If they will infact work once installed? Thanks, I would appreciate ANY info you could give me concerning the Evo gauges being installed into a NON-EVO Lancer. Thanks! -Brian
Old Apr 8, 2006 | 03:05 AM
SJ's Avatar
SJ
I bought EVO 8 cluster and waiting it(shipped).
and some information here.
someone said 'NO it won't work cuz speedometer needle will move same distance as stock but evo has 160MPH so it can read higher than actual running speed'. maybe it can fixed by working on program setting but i have no idea with it.
and the other said 'it works OK just different red line'.(who has EVO one in ES now.) well..N E way..let's see....i'll post when i get it on.
Old Apr 8, 2006 | 11:45 AM
brian38662's Avatar
Cool, whatever you find out let me know, if it works I'll be joining you with the evo cluster. lol Anyway, let me know how it turns out, THANKS!
Old Apr 8, 2006 | 12:30 PM
Lancer2oo3's Avatar
the evo cluster works fine i have 1 in my 03 LS
Old Apr 8, 2006 | 02:34 PM
brian38662's Avatar
So no problems with the RPM's? Or speedometer? I don't know if it would make a difference between a manual and automatic transmission would it? Does it show the mileage from the EVO it was previously installed in? Thanks, Brian.
Old Apr 8, 2006 | 04:50 PM
saecoes's Avatar
wow, i never knew the evo cluster would work in our lancers. there are so many lights on the cluster that will end being inactive
Old Apr 9, 2006 | 01:29 AM
SJ's Avatar
SJ
im glad to hear that man! im not sure 03 evo 8 's cluster has 'ACD indicator' but if it has one then it won't work in our lancer cuz we have 'nothing' for it. well..like i said let's see...
Old Apr 12, 2006 | 03:28 PM
SJ's Avatar
SJ
got 'EVO8' cluster today and it worked OK! it doesn't have ACD indicator(03) and speedometer reading just fine. so much better than 'ES' ugly guage.
Old Apr 12, 2006 | 10:24 PM
Dreamartist's Avatar
Evo gauges work fine on Lancers.
Old Apr 15, 2006 | 04:38 PM
Diavlo's Avatar
I'm going to swap in an Evo 8 gauge cluster with the custom white gauge faces from ebay.
Question is, can I transfer the mileage over to the new cluster? When I took my gauge cluster apart to change the illumination, I seem to remember the LCD screen and chip that holds that information was easily separated so it should fit into the replacement!
Old Apr 15, 2006 | 04:42 PM
Snoogens's Avatar
yeah it should switch over...make sure it will before you by it!
Murder Snake
Nov 4, 2015 02:29 PM
Brijen123
Jan 27, 2008 08:06 PM
EVIL_EVO_VIII
May 9, 2005 01:52 PM
Evilution
Feb 11, 2003 12:44 PM
