Ingalls Alignment Kit
the other advantage to DIY is that you know it got done to your specs. Plus it only takes about 2 hours the first time and I can do mine now in about 30 minutes for toe and camber changes, 10 minutes just to check them.
Ingalls
I had a set on my integra - highly recommend this company's products.
My only advice is that Polyurethane Bushings squeek and have to be lubed regularly - although you sacrifice some performance get rubber bushings.
Actually in looking at the application chart the bushing issue may not apply to Lancers.
My $0.02.
My $0.02.
Lusion
Dec 30, 2005 07:53 PM
