Strut Bars same as Evo?
they dont for the 02's. so im gonna go with no for 03's. i had some front upper and back upper struts from an evo, and the fronts needed modifying to fit, then they rattled the TB at low speeds and just sucked all around. and the backs needed modifing also. i still have the backs in, but i might take them out. and save some $$ for some RRM's and then a tie bar. but from my exp, no they wont fit.
IIRC the evo has a poiny where the (factory) front strut bar ties into the firewall of the car. If it is a aftermarket strut that utilizes this point, then no, it will definitely not fit
^ agreed, they are different. The fronts are spaced similarly but the regular Lancer needs a taller one to clear the throttle body. And the rear ones are completely different. So your answer is a simple no, they aren't interchangeable.
romogst
May 26, 2017 10:27 AM
hatethefuzz
Nov 6, 2008 08:52 PM
greentrbo95gst
Jun 4, 2007 03:01 PM
