WHEEL EXPERTS please help:
Subscribe
Mar 24, 2003 | 03:07 AM
My friend with a 2002 LANCER ES is interested in a set of wheels:
16x7, 4x100, 40mm offset. Will these wheels fit his ES?
Also, what size tires should he use?
thanks in advance!
Reply 0
Mar 24, 2003 | 03:50 AM
The wheels should fit just fine. The only problem could come from the offset, but that will only come into play if you get a super wide tire. With that said... You can go with 205/40 or 205/45 tires and be fine. In fact, you can prolly get away with 215/40 without problems either. There's various tire size calculators you can use to see what the change in overall diameter would be, none of which I have on hand.
Reply 0
Mar 24, 2003 | 01:54 PM
thank you very much
Reply 0
Mar 28, 2003 | 08:30 AM
Hey GlobeCLK, try out this website:
http://www.miata.net/garage/tirecalc.html
Reply 0
Mar 28, 2003 | 12:57 PM
thanks alot. very helpful link
Reply 0
Mar 29, 2003 | 10:39 AM
I like the tire calculator siiiiiiiiick! The many wonderful things I just learned in the past couple of minutes.
Reply 0
Subscribe
