Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
question help pls
Old Feb 2, 2006 | 01:08 PM
joberk3's Avatar
Exclamation question help pls
so i sorta jumped my car today. some ppl say i jumped it. but it was raised pavement then a quick drop-off on a straightaway. so when i got down from the air it sounded like i bottomed out. but i checked the underbody. looks fine. my front left plastic hub/tire is scratched up. how idk. all i did was do a hard right turn (a curve was about 20 ft after the raised ground). and when i drive past 65 the steering wheel seems to wobble/vibrate. not sure if this happened before but can anyone suggest whats wrong, if there is in fact, something wrong? thanks.
*edit* just checked the body and it looks fine. worried abt wobbly wheel tho. only time i remember it wobbling - slightly was if i went 90 +. and tire pressure is lower in the left tires than the right.
Old Feb 2, 2006 | 01:21 PM
gregivq's Avatar
Maybe you bent the wheel?
Old Feb 2, 2006 | 01:25 PM
joberk3's Avatar
seems to roll fine tho? except for that one thing. idk if its me or not but on a curve my car seems to understeer.
Old Feb 2, 2006 | 01:48 PM
JJames's Avatar
you prolly did bottom out, but most likely just the stupid tow hook under the front bumber hit the ground.
I can't tell you how many times I've slammed that thing into the ground. (stupid texas roads)
Just look under your front bumber and see if its dented/all scrached up.
As for the wobbly steering wheel, that sounds like a bent rim I bent the crap out of one of mine (agan stupid texas roads) and I had terable vibrations/wobbly steering wheel. Since you said u just feel the wobble when going around 65 the dent might not be that bad, and might be able to be corrected by having tires balanced. Mine had to be replaced.
Old Feb 2, 2006 | 01:53 PM
joberk3's Avatar
by balanced, u mean getting it all re-aligned, right? the jump was stupid tho, like i jumped and i heard a light thump and im like wtf? bc i know my bumpers or side skirts didnt hit it, and i didnt think i hit an axle or anything. and it all looked fine. ill look under the car soon. it started raining as i checked and no garage so yeah. managed to find the 3ton car jacks so im in luck.
Old Feb 2, 2006 | 03:51 PM
SLVROZ_03's Avatar
Get your wheels/tires balanced... Also, Ive heard horror stories about broken control arms; look at that too.
Old Feb 2, 2006 | 05:05 PM
Chewie4299's Avatar
I had the steering wheel wobble..... It could be off balance tires. That's cheap and easy. In my case the front sway bar was broken along with the mounts. It caused the same wobble that increased with speed. I got it all replaced for $65 so check that out too.
Old Feb 2, 2006 | 05:11 PM
smokedmustang's Avatar
Torque the lugnuts, check if you knocked a "wheel weight" off. Jack up the front of the car (wheel off the ground), and spin it, might be able to see rim "wobble". Good luck.
Old Feb 2, 2006 | 07:24 PM
Walkingchaos's Avatar
tire preasure is your cheap option, then tire balancing, then front alignment, and from there you dont wanna know >=) goodluck.
Old Feb 2, 2006 | 08:11 PM
joberk3's Avatar
well i got a quote for the alignment and its 25. ima put the car on jacks tomorrow and check it out hopefully. ill let everyone know what is really wrong. and thanks for the suggestions everyone.
Old Feb 2, 2006 | 08:13 PM
gbwaacha's Avatar
did you "jump" it on purpose out of curiosity?
Old Feb 3, 2006 | 06:28 AM
Blacksheepdj's Avatar
Could be anything.
Alignment
Tire/wheel balance
Bent control arm/etc
Damaged wheel/tire
Have the alignment place check the car out briefly. Usually things jump out at professionals who know what they're looking for.
They immediately recognized when I bent my front control arm...
Old Feb 3, 2006 | 03:29 PM
joberk3's Avatar
purposely. not at a fast speed tho. that was my mistake. unfortunately i checked out the underside and everything looked okay. one small metal piece that keeps my brake lines secured was off centre (small metal thing) but thats abt it. as for the: Alignment
Tire/wheel balance
Damaged wheel/tire
ill check that out asap.
cerealkeller
Aug 14, 2016 08:24 AM
Xtsy
Jun 5, 2015 10:10 AM
Hitmachine101
Mar 22, 2014 09:23 AM
Ralliart367
39
Jan 29, 2013 07:37 AM
bluemonster2
For Sale - Wheels / Tires
Sep 2, 2009 10:38 PM
