Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Bolt pattern
Old Apr 11, 2007 | 09:43 PM
LancerGTS's Avatar
Bolt pattern
I was just thinking about rims and realized I hadnt even checked to see what the pattern is for the new lancers.
RRM I saw you had some new wheels on yours, what is the bolt pattern that is used and what width did you go with? Thanks!
Old Apr 12, 2007 | 05:04 AM
gts_in_nj's Avatar
bolt pattern is 5x114.3
Old Apr 12, 2007 | 07:14 AM
mtags24's Avatar
try to post some pics when you get them!
Old Jun 4, 2007 | 08:33 PM
Ralliart@PDX's Avatar
I know bolt pattern but has anyone played with the offset on these cars? I am looking @ getting advan rs wheels but need to see if I can mess with the offset @ all. What is stock?
Old Jun 4, 2007 | 11:59 PM
Blacksheepdj's Avatar
Stock on the GTS is 46mm. Not too many people have rims yet, so I'm not sure how much play there is on offset.
Old Jun 5, 2007 | 09:51 AM
csiplon's Avatar
this too has been lingering in my mind...after finals this week my friend said he let me try on his TE37's 17x9 +22mm.....i'm looking to get something in that range 18's rather 17's....i'll post pics ASAP
Old Jun 5, 2007 | 06:22 PM
Hopefully they'll clear the brakes...
Old Jun 13, 2007 | 08:10 AM
chachipower's Avatar
good luck with that, that sounds like RWD offset. You got 24mm less offset and a wider rim.... but then again the Lancer is a new car to me so I dont know what the clearance on this car is... I'd like to know....hmm I got some 18x9.5's in 35mm... haha
Old Jun 13, 2007 | 06:09 PM
SpeedI2acerX's Avatar
now how much can we go +/- a 46 offset? ie can i get a wheel with 33+offset? is it the lower number u go, the clearance problem you'll have?
Old Jun 13, 2007 | 07:14 PM
Depends on the clearance to the calipers and stuff. We'll have to find out over time.
Old Jun 13, 2007 | 07:28 PM
lower offset will push the wheel outwards so too low of an offset will rub the fenders Higher offset sinks the wheel in more causeing clearance problems with caliper/coilover/innerfender. Then when you start playing around with widths it gets a little more confusing becaise now the offsets change to accomodate the width...probably gonna be a little trial and error for some people unless someone out there has an offset gauge which bolts on to hun and allows you to mock up widths and offsets to check for clearance. Summit Racing sells these but I believe its in inches, not mm, but then you can just whip out the calculator
Old Jul 4, 2007 | 08:10 AM
08Lancer89's Avatar
I would like to get 19's later on......
Old Jul 4, 2007 | 12:56 PM
chetman7's Avatar
u think if I lower my car with grip springs on 18x8 wheels that it would be fine. I'm havin the hardest time trying to figure this out
Old Jul 4, 2007 | 12:57 PM
chetman7's Avatar
u think if I lower my car with grip springs on 18x8 wheels that it would be fine. I do not knoe a lot about wheels. just wondering if this would cause any problems cause I knoe stock is 18x7 on the gts
Old Jul 7, 2007 | 06:26 PM
gts_in_nj's Avatar
you should be fine rrm's site has them on a car with 19s.
