Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Progress Springs
Old Jun 16, 2007 | 11:31 PM
zeroth3rm's Avatar
Progress Springs
I have searched around for this but I think my case may be different. I am going to be lowering my car with Progress springs really soon. I read that alignment and a camber kit is not needed, which is good. However, there have been cases of rubbing between the tires and fender. My rims have a 40 offset so I don't know if that will be a problem. The rubbing really doesn't concern me in the front however. It is the back I'm worried about because I have subs which adds extra weight. With the subs I noticed that the rear is significantly lower on stock springs. So does anyone forsee rubbing at the rear with 40 offset on an 05 ES?
Thanks
Old Jun 18, 2007 | 03:21 PM
Blacksheepdj's Avatar
Alignment is needed. When you pull your suspension apart to install them, you're going to ruin the alignment you already have. Just wanted you to be clear about that.
I can't imagine you'll rub, but obviously I'm no Oracle or anything.
Old Jun 18, 2007 | 04:21 PM
Kurt's Avatar
I never rubbed when I had them.
