Installed: Tein S-techs
^^ solsonic is correct.
I've been pushing it hard into corners, and wen I say hard I mean hard. ive yet to encounter any problems. I'm mixed on it right now cause I also have an aftermarket sway bar which can effect my judgement of control and handeling
If you've never done it before then get it done at a suspension or tuner shop. Otherwise you risk killing yourself (literally) if a compressed spring shoots out from its housing because you don't know what you're doing.
'08 lancer springs can be removed without a spring compressor. There is a small amount of preload on the rears, but only a couple of pounds. Just don't stick your face over the top hat when you unbolt it and you will be fine.
S Tech Installed
This is how a Lancer should come off the lot.
They are TEIN S TECHS
http://www.automationinstaller.com/s...s/DSCF4218.JPG
http://www.automationinstaller.com/s...s/DSCF4219.JPG
