Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Drop/Tire Question
Old Mar 18, 2008 | 06:19 AM
Khoranic's Avatar
Drop/Tire Question
Im another looking into the DC-5 Tenzo Rims... (Red and Black) but um, im going to have a 1.5" Drop all around and was wondering what kind of tire should work with no problem... I was thinking either 225/40R18 or 235/40R18
All input is greatly appreciated!!
Old Mar 18, 2008 | 08:01 AM
blancy612's Avatar
i'm prob going 4 the same rims in the futuree....i'm thinking to get tein s techs....wondering if it'll fitt... o believe teins are 1.2 and 1.4?
Old Mar 18, 2008 | 04:54 PM
CamShaft's Avatar
those tires should fit fine. There is lots of room in the wheel wells...not so much width in the front (tight turning radius) but lots of room height wise.
Old Mar 19, 2008 | 05:30 AM
Khoranic's Avatar
i did read the post where someone said they had a 1.2inch drop with 235/40r18 on theirs.. and no rubbing what so ever. i was just worried maybe that extra .3" may come into play
Old Mar 28, 2008 | 04:44 PM
1saiah's Avatar
is it possible to put tires that are 195/50/16 on for ES rims?
Old Mar 30, 2008 | 01:06 PM
Blacksheepdj's Avatar
It's possible. But it's a bad idea. It'll throw your speedometer WAY off. 205/60 is what you want.
If you put on those tires, you'll be over 7% off. So (just an example) when the speedo says 60 (97kph), your car will actually be moving about 88mph.
