Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Wheel help
Old Jan 31, 2009 | 06:50 PM
GiLizILL's Avatar
Wheel help
Ok peeps, I have an 09 Ralliart and I need ya'lls GTS expertise since the Wheels are practically the same
Im looking to upgrade the tires to 225 and the rims to 18x8 with offset +45
Will it work with no probs?
Thanks
Old Jan 31, 2009 | 10:24 PM
cRc`22's Avatar
no problem at all.. u could even go 235/40-18
Old Feb 1, 2009 | 09:07 AM
eyekyu's Avatar
will an 18x8.5 fit?
Old Feb 1, 2009 | 10:49 AM
cRc`22's Avatar
depends on the offset
Old Feb 1, 2009 | 04:41 PM
GiLizILL's Avatar
so 225 with 18x8 will fit no prob at all?
anyone else can confirm this?
Thanks!
Old Feb 1, 2009 | 07:53 PM
eyekyu's Avatar
what you recommend with no rub or spacer
Old Feb 1, 2009 | 08:51 PM
cRc`22's Avatar
Thanks!
im running 18x8+35 235/40-18 u will be running an offset that will keep ur tires tucked further in and a thinner tire so i can confirm u definately wont rub.. lol
Old Feb 1, 2009 | 08:59 PM
cRc`22's Avatar
i know a guy running 19x8.5+45 215/35-19 so im sure if u went 18x8.5+45 theyd fit.. id swap ur stock tires over first to see how much wider of a tire u could fit on there
Old Feb 7, 2009 | 01:17 PM
eyekyu's Avatar
how about +38 offset?
Old Feb 7, 2009 | 09:35 PM
GiLizILL's Avatar
OK im officially going 18x7.5 with +49 on some 225 45/18
how does that sound?
Old Feb 7, 2009 | 10:34 PM
I Am God's Avatar
are u talkin stock ride height? if not what suspensions r being run (how low) i wanna be able to run widest rim 18's with hella lowpro, lookin into coilovers will i be needin to offset enuf to have tires tuck if i wanna lower coils hella?
Old Feb 8, 2009 | 11:14 AM
eyekyu's Avatar
18x8.5 + 38 anyone?
or an i gonna need a spacer?
Old Feb 8, 2009 | 12:20 PM
cRc`22's Avatar
18x8.5 + 38 anyone?
you might have to roll the rear fenders
Old Feb 8, 2009 | 04:10 PM
bye2u's Avatar
might want to go with 225/40/18 to keep close to the same rolling diameter of stock or your speedo will be off abit.
Old Feb 10, 2009 | 03:37 PM
eyekyu's Avatar
thanks for all the help, last question any tire size or should i ask the shop and see what will fit? i wanna go 235 or 240
