Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
fillament question
Old Oct 5, 2003 | 04:05 PM
trance's Avatar
fillament question
Just woundering if 17x7 4x100/108 Offset 42mm wheels fit on a Lancer OZ??
Now I know the OZ wheel size is 4x114.3.
Whats the diff between these two wheels?
I know the size diff between the stock 15 inch and the ones I'm askin about are 17 inchs but I am lost regaurding the diffrence between the 4x100/108 and 4x114.3?
Will these new wheels fit?
Old Oct 5, 2003 | 09:55 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
ouch, I don't think that will fit. The rim size and offset are perfect, but those bolt patterns won't match the lugs on your car, unless you swapped for some Lancer ES parts (which uses 4x100).
Old Oct 6, 2003 | 02:51 PM
trance's Avatar
So your saying that if I change out the lugs it would fit?
These rims I'm asking about are the OZ F1-Cup wich I have been wanting for a while and finally found them.I'm pretty sure if I go the local tire shop they can change out the lugs right?Should be just like replaceing a worn lug correct?
Old Oct 6, 2003 | 03:03 PM
HobieKopek's Avatar
You'd need to replace the entire hub. Bolt pattern = # of bolts x diameter of the imaginary circle they create.
You're talking about wheels whose circles are too small for the OZ's hub.
Old Oct 6, 2003 | 03:04 PM
Tristar's Avatar
Its not the lugs, put where they are placed, meaning the whole hub would have to be changed to that of the Lancer ES. I guess it could be done, but it will probably cost ya a decent amount of money.....
By the way, prefered offset for our cars is 40 mm, but 42 will be fine.
(Nice Andrew, ya beat me to it.....lol)
Old Oct 6, 2003 | 03:07 PM
jojoskates's Avatar
Plain and simple: 4X100 will not fit a OZ Rally
Old Oct 6, 2003 | 06:26 PM
trance's Avatar
Thars all I need to hear...It's just that the OZ F1-Cup is the nicest looking rim that OZ racing makes in my opnion.Looks like I'm out of luck
