Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Thinking of getting wheels would this fit?
Old Nov 17, 2009 | 06:41 PM
funkad3llic's Avatar
would these fit? just wondering before i get it. oh and i also lowered my car too with the tein s-techs so thats about 2" drop
Font: 18x9 5x114.3 et 45
Rear: 18x10 5x114.3 et 40
Old Nov 17, 2009 | 06:51 PM
JHizzle's Avatar
first of all i wouldnt run staggered on a FWD car..it will cost you more moeny down the road than anything and you'll have terrible understeer
second your going to need some major fender work done to the rears to fit a 10inch wide wheel back there and probably something done in the front, especially if you have a drop.
my advice would be look into different wheels and make sure they all match, the offset dosent have to match but you need wheels that are all the same with, for example both could be 18x8.5, you can run 18x8.5+45 in the front and 18x8.5+35 in the back but try to make sure the diameter matches
Old Nov 17, 2009 | 06:54 PM
Kenaki's Avatar
With those size, your most likely to rub big time. In order to fit those, you have to do lots of fender rolling and use big negative camber. Even so probably rub with 18x10. I am not sure about those 18x10 wheels. That would be like 255 tires the minimum which is still too wide. Someone on here are already 18x9.5 and have to do fender rolling and run on negative camber. Recommended are 18x8 to play safe with no fender rolling on tein s tech. Or some people on here run 18x8.5 with coilovers.
Old Nov 17, 2009 | 07:02 PM
cool! thanks for the input guys
buckmarley
Mar 7, 2013 09:12 PM
08XGSR
May 17, 2010 12:25 AM
flipsidekilla
Oct 26, 2008 05:08 PM
limmerZ
Oct 26, 2008 04:25 AM
Jovani
Dec 6, 2004 11:35 AM
