Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Coilover Adjustments
Old Mar 19, 2010 | 09:03 AM
mattchan99's Avatar
I'm thinking about purchasing coilovers, but the concern if its reasonable to get adjustable damping ones if the access to the rear strut coilover adjustment nut/knob seems impossible. If i remember correctly, from removing the carpet and the shell housing to the rear struts, theres only 2 bolts showing that fastens the strut to the chassis and then theres a wall of metal that covers the rest of the assembly. So if i do purchase adjustable damping coilovers, to access the rear damping adjustment, i would have to either drill/cut a hole into the metal housing to create access or I need to remove the rear strut and adjust it and reinstall them. I drive a 2008 Lancer ES.
Am i right on my assumptions? Has anyone purchased adjustable coilovers and found an easy way to adjust their rear damping?
Old Mar 20, 2010 | 05:51 AM
kalpakiotis's Avatar
depends on what you want to do. i have them installed in my car and i love them. i however used a hole saw big enough to pass the flex drive through this hole. The coilovers will come with this flex drive if you get the megan ones. then i just cut a couple of slits in the carpet and it is tucked away between the foldable rear seats and the tower. All i need to do to adjust is lower the seats and the knob is right there with easy access. The rears is def a 2-man process if you do this. It was kinda hard to hold everything in place.
eastcoastoutlaw
Oct 3, 2013 11:10 AM
aziankingz
Dec 28, 2011 07:20 PM
RavSpec
EvoX 'For Sale' Suspension / Brakes / Handling
36
Jul 28, 2010 06:20 AM
Neal@tirerack
Evo 'For Sale' Suspension / Brakes / Handling
Mar 6, 2010 09:49 AM
Vivid Racing
16
Jul 15, 2009 05:05 PM
