Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
16" wheel question
Old Dec 4, 2003 | 11:40 PM
myoung's Avatar
16" wheel question
I'm looking at a set of wheels that are 16 X 7 with a +40 offset. What are the odds of these rubbing with 215/45-16 tires and that offset. Sorry if stupid question, but new to the whole import thing.
Old Dec 4, 2003 | 11:51 PM
kensuke's Avatar
honestly, i don't see how u could rub unless u dropped like, 2.5 inches... even then, u may be able to pull it off. 16" is a pretty small rim.
the offset actually sounds about right, and a 7" rim will not rub. i have 215 width tires and they don't rub... mine are 18s
Old Dec 5, 2003 | 12:40 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
That should fit perfectly. I have 16x7 rims with a 42mm offset and 215/45/16 tires, and they fit just fine. I doubt 2mm will make much difference. And that size is even better for you, as it is almost the same diameter as your stock tire size. It's a little small for me, but that's good for the autocrossing I do on them. I'd say you have a winning combination there, go for it.
Old Dec 5, 2003 | 12:56 AM
myoung's Avatar
Thanks guys, that's what I wanted to hear.
Old Dec 5, 2003 | 01:42 AM
ghostrider's Avatar
Hell, I had (swapped for winter steelies) 205/40/17s with more than a 2.5" drop and only had rubbing if I turned extremely quick or went over speed bumps entirely too fast.
Old Dec 5, 2003 | 09:02 AM
myoung's Avatar
The thing I wasn't sure about was the 215 instead of the 205 on a 40mm offset instead of a 42mm-45mm offset. Don't know how close the 'correct' set-up gets to the wheel house. I'm used to RWD offsets and big *** tires that barely fit in the back, and skinnys up front with more than enough room.
Thinking about it now though, it's only a 7.5mm difference bewtween a 205 on a 45mm offset and a 215 on a 40mm offset which is only around a 1/4", so I guess I'm worried about nothin. Just took my brain a minute to process the reverse offset thing.
Old Dec 6, 2003 | 07:50 AM
cdyancey's Avatar
for your tire size calculation go to
www.miata.net/garage/tirecalc.html
Old Dec 6, 2003 | 08:09 AM
tswift's Avatar
IF you want to do it the old fashioned way follow this:
215 / 25.4= ? ?*.40=?
?*2+16=final diameter.
Old Dec 6, 2003 | 08:49 AM
cdyancey's Avatar
lol
Old Dec 7, 2003 | 12:09 AM
Moderator
Bomb Squad Unit #02
yeah, but I think he was worried about the overall width fitting in the fender, not so much the diameter change. The concern here seemed to be rubbing.
BLKRalliArt04
136
Apr 16, 2015 05:15 AM
Evodreamer28
11
Sep 16, 2009 08:21 PM
darkmitsu
Apr 26, 2008 10:36 AM
EVOCOLLABORATE
Jun 29, 2005 11:22 PM
kencope
10
Jun 19, 2003 02:55 AM
