Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Breaks squeeking .
Old May 12, 2014 | 06:57 PM
Thahomeboyb's Avatar
Breaks squeeking .
My lancer brakes are squeeling almost everytime I use the breaks and it is getting quite irritating . It doesn't feel like I need new ones the seem very dry though . Can any one hell me out
Old May 13, 2014 | 03:28 AM
RT78's Avatar
Front or back? My back brakes squeal all the time, but I still have the factory shoes in back which are known to do that. If it's the front check to see how much pad material you have on the front pads, you may have gotten down to the squealers already.
Old May 13, 2014 | 07:08 AM
marcouxa1's Avatar
It's the materials used in your brake pads. Usually performance brake pads squeal like hawk hp+ or wilwoods.
Old May 13, 2014 | 12:23 PM
I'm not sure what brakes are on it becuase they were on when I got the car. I want to say it's coming from the front. The front rotors look clean and shiney last time I took the front wheels. But the back look very corroded .
Old May 13, 2014 | 01:44 PM
RT78's Avatar
If it wasn't squealing when you got it, I'd check how much material is left on the pads. I think you have to have about 3/16 an inch or less of material before the squealer tabs start touching the rotor. If the pads are decent(tabs aren't touching the rotor) then it's just the material, like marcouxa said.
Old May 13, 2014 | 02:00 PM
I'm thinking that replacing the break pads will be good . Should I get ceramic brakes which are about 50.00 or the oem ones which are about 30.00
Will the ceramic breaks increase the braking performance.
Old May 13, 2014 | 05:44 PM
marcouxa1's Avatar
Ceramic perform better when hot but are less performant when cold. EOM rotors and pads is probably the ideal if you dont want any sound but not all aftermarket/jobber brakes squeal either so that's up to you.
Old May 13, 2014 | 07:52 PM
I'm looking for something that doesn't squeel , I mean I do drive kinda with a heavy foot. What do you mean by they perform better when heated .
Old May 14, 2014 | 02:52 AM
RT78's Avatar
When ceramic pads heat up from use their stopping ability gets better, and he's right, you run the risk of at least a little squealing no matter what you get. I don't know of any issues with the oem pads, but for the back brake shoes they switched materials due to squealing when applying the brakes. Another member mentioned that the oem pads are about $50 from the dealer, and the oem is semi-metallic material.
Old May 14, 2014 | 12:41 PM
Oh alright I guess I'll lean towards the oem and I saw them online new for I think 35.00
Old May 15, 2014 | 06:18 PM
Okay so now it seems like my right brake def. needs to be replaced because when I put my foot on the brake it makes a scratching/growling noise !
Old May 17, 2014 | 02:33 AM
RT78's Avatar
Sounds like it's time for some new pads
Old May 17, 2014 | 08:10 AM
But is it possible that I only need one brake pad because it only comes from the front right of my car . Or should I just replace both .
Old May 17, 2014 | 09:36 AM
marcouxa1's Avatar
If your pads make that kind of noise and your pads are to the metal you need a new set of pads (comes in pair for both sides) and 2 new rotors because your rotor surface is going to be destroyed where your finished pad is.
Old May 17, 2014 | 09:45 AM
Damm looks like I'm not buying a front bumper any time soon . Should I get slotted or non slotted rotors ?
