FI - Clutch Slippage - New To Forum
Hey Guys,
While i'm nowhere near new to the EvoM boards, i am new to the drivetrain tranny section unfortunately haha.
Turbo setup - T25 running 7lbs I/C. Putting down (at my best estimate) about 190hp to the wheels.
My clutch started slipping in the shift from 1st to 2nd a few weeks back but it would eventually grab and i would have no problem on full throttle in higher gears HOWEVER, my clutch is now real bad. Its the stock clutch and i knew a clutch upgrade with FI was eventually needed so i knew this day would come. I can't go WOT in anything over 1st gear otherwise the clutch slips and i go nowhere, so its pretty much shot. I'm not looking for a huge upgrade over stock, and i'm not bumping the boost up at all or doing any more mods to the car. What it is now is what its staying until i sell it in a year. So what clutch do you recommend? I tried reading up a little bit and some people say stage 1, some say stage 2. The stage 1 people say you dont need stage 2 unless you're going to start pushing 240+ at the crank, but the stage 2 people say thats not true.
Any suggestions on what clutch to get and brand? Cost is an issue here too. I'm still torn on whether i'm having a shop do it or throwing myself and my friend under my car and doing it ourselves. What would a typical local shop usually charge for labor on a clutch install if i supply them with the clutch and TOB.
Best bet is stage 2, stage 1 is basically just a stock replacement with a slightly higher holding power (depending on which company of course). WORKS and RRM are probably your best bets, although I think there are other sources out there.
Originally Posted by ozrally0303
i got my stage 2 act and love it chirps third like hell still with 20k on my turbo setup
ok maybe i didnt mean chirp more like burnout i got an idea lets see a vid of u gettin ur 100hp lancer to chirp 3rd with a quick shift and stock clutch? and i dont have stock narrow tires either
