Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
quick question.......
Old Sep 27, 2007 | 04:13 AM
MurphDurph's Avatar
Couldn't find much in the search, but can a 1g eclipse clutch fit an 02 oz?
Old Sep 27, 2007 | 08:01 AM
senate6268's Avatar
It certainly can. Any clutch for a 89-94 2.0L DOHC Non-turbo. I've been using 1G DSM clutches for over 4 years now in my '03 OZ. Pretty good concept, too, considering that a stock clutch for the DSM will hold more than a stock Lancer clutch. And a "stage 1" clutch for a DSM holds like almost 300 ft/lb of torque. Enjoy!
Old Sep 27, 2007 | 08:19 AM
ILovE WHEELS's Avatar
cool did not know this.....so i asume pressure plateplate will work too
Old Sep 27, 2007 | 10:15 AM
senate6268's Avatar
You need to change both the pressure plate and clutch disc to use the DSM clutch setup.
Old Sep 27, 2007 | 11:31 AM
MurphDurph's Avatar
Sweet....so would a stage 3 racing clutch with a lightened flywheel be too much for my lancer which only has basic bolt ons? (Intake + exhaust)
Old Sep 27, 2007 | 01:09 PM
senate6268's Avatar
A stage 3 clutch would probably be a 4 or 3 puck clutch. You would hate yourself for installing it. The engagement is very harsh and completely unnecessary for your mods.
Old Sep 27, 2007 | 01:35 PM
SLVROZ_03's Avatar
^Yep, plus there is a thing such as "too-much clutch" that'll not be good. A stg1 in the forementioned "DSM" setup will do you well...
Old Sep 27, 2007 | 02:49 PM
MurphDurph's Avatar
Oh ok....wow thanks for the info guys. Ya'll saved me from makin a mistake I was told my tob may be goin out and ill need a new clutch pretty soon.
Old Sep 27, 2007 | 02:50 PM
lancer2show's Avatar
i had a stage 3 clutch on my 1g dsm....SPEC CLUTCH...it grabbed pretty hard. not good for dd. thats why my tranny went messed up and i had to sell it. i would stage 2 for modded n/a or turbo for dd
Old Sep 27, 2007 | 04:17 PM
i used to have a 6 puck clutch in my civic with a super stiff pressure plate and i loved it grabbed so nice. sucked at first but after i got used to it it was nice
Old Sep 27, 2007 | 05:36 PM
mcgarvey's Avatar
From what I understand, 04s are slightly different. If I wanted to go this route, could I buy a 1G DSM clutch/pressure plate, and then pick up a throw out bearing from the local mitsu dealer that's designed for the 04 lancer?
I'm assuming everything bolts up directly and there is no modification involved?
Any advice would be appreciated.
Old Sep 28, 2007 | 07:58 AM
senate6268's Avatar
The only thing different in the 04-06 Lancers in the throwout bearing and clutch slave cylinder design. The pressure plates and clutch discs are the same. The specs for clutches for 4G93 Mirages, 4G63 NT DSMs and 4G94 Lancers are the same. They are 215mm discs. The differences between them all is their torque capacities.
Old Sep 29, 2007 | 04:36 PM
mcgarvey's Avatar
Are aftermarket TOBs available? Or is OEM the only way to go?
Old Sep 29, 2007 | 05:49 PM
senate6268's Avatar
There aren't any aftermarket TOBs per say. There are OE ones that are made by other companies to "meet or exceed factory specs", etc. etc. etc. In reality, OEM is the best way to go.
Old Sep 30, 2007 | 06:24 AM
mcgarvey's Avatar
Like I said, I have an 04. I've heard that the TOB they use is the same as the 1g DSMs and 4G93 Mirages. 2002-2003 do not. Can anyone confirm?
