Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
Looking for a Cluch for an 06 Lancer
Old Mar 9, 2009 | 08:55 PM
LancerEVA06's Avatar
I'm trying to find some other options besides the clutches from SpeedCorps, RRM, and OEM. My DD is an 06 Lancer ES. The clutch is starting to slip a little at higher RPM at the beginning of a shift. Anyone have any suggestions?
I can get a EXEDY organic OEM organic clutch and pressure plate at AutoZone for about $270 (Lifetime Warranty, no questions asked)... but that's the stock clutch, I want something a little better.
Old Mar 10, 2009 | 08:57 PM
I came across some stuff while I was at work tonight. The clutch kit for the 2006 Lancer is correct (as far as the Disc and Pressure Plate). The throwout bearing is different, but I found the right one from a 98 Mirage 4G93. Now my question is; Would a clutch set from a 98 Mirage work on the 06 Lancers? The clutch kit for the Mirage has the correct release bearing, and the Disc is identical (even matching part numbers). The pressure plate looks very similar (color differences) but can't find a part number.
Old Mar 11, 2009 | 02:24 PM
mcgarvey's Avatar
Yes it will, and so will a clutch/bearing/pressure plate from an 89-94 non-turbo eclipse.
Old Mar 11, 2009 | 08:32 PM
Now the question for all of you is this; which one would you guys pick over these 2 options.
$297.02 - EXEDY
$85.59 - Valeo
Both carry a lifetime warranty and that's total cost including taxes.
Old Mar 14, 2009 | 03:18 PM
mcgarvey's Avatar
They're both good brands and should be about the same. Where did you find the valeo for that cheap?
Old Mar 15, 2009 | 07:13 AM
AutoZone with my discount. Looked up a 98 Mirage 4G93.
Old Mar 25, 2009 | 11:06 PM
japordie's Avatar
are these oem replacements? or an upgrade on the exedy and valeo
Old Mar 26, 2009 | 08:06 AM
They are supposed to be OEM replacements, but I contacted the vendor of the clutches and they said the clamp force on the pressure plates are 2100lbs on both. If memory server correctly the clamp force stock is 1700lbs.
