Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
cel for o2s when the work fine?
Old Oct 23, 2009 | 10:08 PM
commandwolf's Avatar
I drive a 03 OZ rally. I purchased and installed a Greddy ti-C cat back approximately 4 months ago. About a month ago my CEL came on. I figured it was a bad o2 sensor and it was. However my mechanic told me that the code was for the o2 sensor and that was what was turning the CEL on but there was nothing actually wrong with the sensor it's self. He thinks it is the back pressure of the catback now that it has been covered in carbon. He said i could replace the o2 sensors to fix the problem so i could pass inspection but more likely then not the CEL problem would just come back. Has anyone encountered this problem before or know a way to fix this permanently with out replacing my cat back?
Thanks
Old Oct 23, 2009 | 10:18 PM
MrLam's Avatar
You could always get the CEL eliminator from RRM.
http://www.roadracemotorsports.com/s...products_id=36
Old Oct 24, 2009 | 06:06 AM
thanks man ill email rrm and see if they think that will fix my issue
Old Oct 26, 2009 | 04:50 AM
bump i don't think that will fix the issue
Old Oct 26, 2009 | 08:18 AM
blaze_125's Avatar
What's the code?
Old Oct 26, 2009 | 08:20 PM
Daedalus2051's Avatar
I have a cat-back exhaust and haven't had that problem at all. I've had it for about 6 months now at least too...
do you done anything to your computer or fuel injection system? if you're running rich that would more than likely kill the o2 sensor
Old Oct 27, 2009 | 06:44 AM
nope just the cat back...i did put in new plugs but i don't see that causing an issue... maybe my sensors are just junk ..i m gonna try the non-fouler cheat tomorrow and if that doesn't work ill get new sensors
my mechanic didn't tell me what the code was i'll have to call him and ask him he just said the o2 was trigering the cel but there was nothing wrong
Old Oct 27, 2009 | 08:10 AM
blaze_125's Avatar
Don't beleive anything your mechanic tells you before you get our opinion
Drop by Autozone or something, get the code and come back here
Old Oct 27, 2009 | 04:55 PM
Jehuty's Avatar
I'll need to grab my code, because my code won't go away either. It pretty much resets itself occasionally, but it doesn't stay off.
Old Oct 27, 2009 | 04:59 PM
02-Lancer-Es's Avatar
I have not had a code at all on my car for over a yr and a half ! lol
And i have Header/Downpipe/Stock Cat/ Evo2 Catback.
You may have a a bad cat !
Go to Autozone and tell them tyo pull your code . Then i would be able to help you pinpoint the problem !
Good luck ,
Antonio .
Old Oct 28, 2009 | 08:11 AM
Jehuty's Avatar
I have full 2.5" exhaust...sooooo...
Old Oct 29, 2009 | 08:33 PM
lol i got the codes they are P0135 (bank 1 sensor 1) and P0135PD (bank 1 sensor 2)
i was told this is a general "o2 sensor not working" code
Old Nov 3, 2009 | 10:10 AM
blaze_125's Avatar
could it be a plugged cat?
Old Nov 5, 2009 | 07:10 AM
ended up just being the oxygen sensor...he took back all that crap he said about my exhaust being the issue and was like "yea of course your o2 is broken" after a week of me exploring all possible problems and being like it seems like it is just the o2
thanks though guys for your help lol
Old Nov 5, 2009 | 08:33 AM
Jehuty's Avatar
Are you serious? you just needed a new O2?
