Clutch makes loud sound (video)
The metal piece going into your tranny that the plunger is pushing on is your clutch fork. It is what actually pushes onto the pressure plate and releases the clutch disc allowing you to shift gears. To fix the issue you will have to drop the tranny and examine if in fact you can just lube up the parts in there or if they will need to be replaced due to corrosion.
