Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
4G94 Auto to Manual
Old Nov 17, 2015 | 10:25 AM
RobGinSki's Avatar
4G94 Auto to Manual
I'm converting my auto to manual.
I work at my family owned mechanic shop so I will be doing the labor.
No matter what anybody says I'm still doing the swap lol so no negatively only want answers lol.
I will be buying new and used parts.
Correct me if I'm wrong
02-06 lancers are the same for engine and trans.
I'm buying a 2003 Manual Trans.
Will a 2006 flywheel fit on the 03 trans.
Any websites you guys can recommend on getting parts.
Are there any interchangeable parts I can use without problems.
When I buy a new ECU. Does It need to be updated for the manual trans if it's already a manual lancers ECU(from a 2003 already)
If anybody can help toss a comment below or send me a message.
Once again I'm going to do this no matter what if it's worth it or not Im swapping it. Money doesn't bother me when i am having fun working on projects.
Old Nov 18, 2015 | 04:26 PM
jakermeister's Avatar
02-03 lancers have a internal slave. 04-07 lancers have a external slave. The flywheels are the same as well as clutch. You'll need a manual ecu as the auto ecu you have now may throw a check engine light when some of the electronics are unplugged. I would probably opt for a 02-03 ecu because they have more definitions for them when tuning. The auto and manual roms are definitely different. The auto rom is 512kb and the manual is 256kb. Road race motorsports has a few lancer parts but if you do some homework you can find what you need.
Old Nov 30, 2015 | 09:42 PM
jimbo74's Avatar
Veteran: Air Force
check out the thread a few posts down
Old Feb 9, 2017 | 05:43 AM
joshua webb's Avatar
is it possible to do a 4g63 head swap on a 4g94 Sohc see my brother has a mirrag and he told me I can do a 4g94 dohc swap but I have a 4g63 sitting in my place and I kinda want to do something with it. I'm going to post a picture of the motor I got
Old Feb 9, 2017 | 05:49 AM
I got this from Craigslist for $1,700
Old Feb 9, 2017 | 06:39 AM
CrAnSwIcK's Avatar
why would you swap heads if you have a complete 4g63
also. no you can't put a 4g63 head on a 4g94...
Old Feb 11, 2017 | 10:33 AM
marcouxa1's Avatar
On top of all that i would say the 02-03 and 04-06 use different fuel system types....the 02-03 have a FPR and a return style fuel system as the 04-06 use a returnless fuel system with the FPR inside the fuel pump unit.
Old Feb 14, 2017 | 06:23 PM
ok so the 4g63 is dohc my 4g94 is a single but I can do a 4g94 dohc sawp why can't I do the head swap
Old Feb 14, 2017 | 11:00 PM
CrAnSwIcK's Avatar
because the engines are not even the same family, the won't bolt up...not to mention the 4g63 bottom end is at least twice as strong...why would you even want to use a weak block with a 4g63 head...did you plan on ditching the turbo?
Old Feb 15, 2017 | 08:38 PM
OK see there two people using this boat me and my brother I have the evo engine and the money and brain power for the lancer swap but he wants to just add some parts from an evo and try to frankinstine his so the question about the ego head swap post is my brother I'm the on that owns the 4g63 motor from now on to know the difference between use two I'm going to leave 4g63/Oz at the end of my post... Just so you can tail who is who 4g63/Oz
Old Aug 5, 2025 | 06:03 AM
Ricky123's Avatar
Attempting manual swap using manual trans from 2003 eclipse GS
Hey man did you ever get the swap figured out? I’m jus bought a parts car with the 4g64 and 5 speed manual and want to manual swap my oz rally and then engine swap later down the line, trying to do my research before starting the swap but it seems every thread is just people saying DONT, but I’m going to anyways, what did you do for your wiring harness situation and did you flash your ecu or use a different one? Any advice would help thanks
NoClanSWAT
Lancer Engine Tech
Jan 23, 2013 05:55 AM
dspucches
Oct 29, 2011 12:36 PM
bettorer
Aug 30, 2005 09:52 PM
