fuel gauge wrong! help!
Old Oct 24, 2004 | 06:05 PM
02izzel's Avatar
something wrong with my fuel gauge?! yah, im NOT on full! obviously im gonna have to get an auto meter fuel gauge and put it on my a-pillar if i wanna sell this thing.. MY question is..what do i have to do. im not the best with electrical ****. where do i have to run the wire to for it to read the amount of fuel properly?
OR can i fix the stock one? anyone else had this problem? thanks. - ian
Old Oct 24, 2004 | 06:26 PM
Megadeth2118's Avatar
When you installed the new gauge face did you position the needles correctly? Looks like your temp gauge is wrong too.
Old Oct 24, 2004 | 06:28 PM
pgmike's Avatar
if you mess with the gauges this is usually what happens, youre speedometer is also probably off a little.
Old Oct 24, 2004 | 06:32 PM
02izzel's Avatar
how correct you are. theyre both wrong. the spedo is right. here on base they always got those things that tell you how fast youre going..after i put that white face on i made sure to drive by one.
Old Oct 24, 2004 | 10:03 PM
02izzel's Avatar
anybody?
Old Oct 25, 2004 | 10:45 AM
HobieKopek's Avatar
The face has to click into place when you install it. Chances are it's not clicked in and it's keeping the needles from moving freely. Fuel gauges are notoriously inaccurate, so don't expect it to be totally precise, but you can have it like it was stock if you go back and reinstall the needles (I'm willing to wager).
Old Oct 25, 2004 | 12:32 PM
02izzel's Avatar
thanks..ill try that. I THINK they can move freely...it goes up and down when i shut the car off and turn it on. when i start the car up, it SHOOTS up to full.
the temp gauge does almost the same, but it has a lil more movement than the fuel gauge. the fuel gauge always say full, the temp starts @ about the midpoint with these COLD mornings in alaska. but its still wrong.
Old Oct 28, 2004 | 06:29 AM
HobieKopek's Avatar
Fill the tank. Get the car home and bring it to operating temp (run it for like 10 min or maybe more since you're in Alaska). THEN put the needles on. Temp should be in the middle (maybe slightly below) and obviously fuel should be at full. If your tach and speedo are ok, then temp and fuel are "close enough" so don't sweat it.
Old Oct 31, 2004 | 02:03 PM
02izzel's Avatar
thanks for the tips. close enough is good to me, its not gonna look too cool when i go to trade it in and those are completly jacked up, close enough will work for me
Jkuti13
Jan 30, 2016 03:35 PM
magnex265
Aug 7, 2015 09:24 AM
EmGee
Jun 26, 2015 10:53 PM
ChaseEvo8
Jun 24, 2014 11:12 PM
FQA-EVO
Mar 30, 2014 12:56 AM
