Shifting gears...
Old Jan 25, 2003 | 05:11 PM
on3ofak1nd's Avatar
Another thing you might want to consider if you're having trouble getting into 1st from N is depressing the clutch again and then trying to shift, it states in the manual that if it feels difficult to shift from N to 1st depress the clutch again.
-wes
Old Jan 25, 2003 | 05:37 PM
MitsuMan's Avatar
I also have the problem shifting from first to second but i also started to notice the samething coming back to second from third
Old Jan 25, 2003 | 05:38 PM
StreetLancer's Avatar
Might it have to do with syncromesh? I think that first is the only non-syncromeshed gear or something. Something like that.
I've also noticed it get worse during cold snaps down here.
Old Jan 29, 2003 | 06:02 AM
visualkei72's Avatar
Well, sequential shifting can't be the problem, all FWD cars have it.. Hmm..
Well I cracked my own problem... It's me.
I suggest that nobody tries to "powershift" it. I used to do that a bit, but stopped. That wasn't the problem though. It's timing. I've noticed that you need to let your foot delay a few nanoseconds from the definite position of the shifter in 2nd. You could correct this problem with a short-shifter. I better go get one soon.
--- Kei
Old Jan 29, 2003 | 03:02 PM
pjal84's Avatar
--- Kei
SO TRUE. That is exactly it. I still haven't even figured out the timine just right for 2nd. It's just very strange.
Old Jan 29, 2003 | 04:37 PM
redbeard's Avatar
Kew, I thought it was just me.
Old Jan 29, 2003 | 04:44 PM
hbmike's Avatar
i had the same problem. try to not pull so hard or fast back on the shifter when going into second. it will help it go smoothly.
Old Jan 29, 2003 | 11:02 PM
diamondstar03's Avatar
first to second a little grind occasionaly, but just keep your foot in it with a short shifter, and after about 12,500 miles mine straightened out.
It's almost as if the car has adjusted to my driving ability.
Old Jan 29, 2003 | 11:04 PM
never let out of the pedal!!
just let the synchro's do the work, but make the shift quickly, and
knowingly!!!
Old Jan 29, 2003 | 11:29 PM
Juiced02 Lancer's Avatar
its just a mitsubishi tranny thats all if u guys have ever drove the eclips ull know what im talkin about it a given that a mitsu tranny has shifting problems only in 1st to 2nd and eventualy reverse once broke in
Old Feb 1, 2003 | 10:05 AM
Like I said, I think the 1st gear is the only non-sycromeshed gear, so, that'd lead me to believe that the "problem" stems from that.
