rrm header
Old Jan 2, 2003 | 02:46 AM
nightrider's Avatar
rrm header
i have two problems:
1. first my servie engine light is on now after the header install.
is this normal and if it is then how can i fix it?
2. my exhaust makes a sputtering noise of some sort. it is like
when you hold your lips together and blow. is this normal
and how can i get rid of it?
Old Jan 2, 2003 | 05:25 AM
bdavie's Avatar
the cel is normal, you need to get a MIL eliminator to get rid of it.
as for the sputtering, does it come from near the headers or from the exhaust pipe?
Old Jan 2, 2003 | 05:42 AM
BostonLancer's Avatar
Both of those symptoms are completely normal and expected with any header.
Remember, you just removed the first catalytic converter!
Get a MIL Eliminator and you should be fine!
Old Jan 2, 2003 | 05:57 AM
mcbrown35's Avatar
The sputtering sound would be a result of less back pressure wouldn't it?
How is the mil eliminator installed, does it screw in between the header and O2 sensor?
Old Jan 2, 2003 | 06:18 AM
uranium9v's Avatar
It looks like a transformer with a couple wires coming out of both sides. You wire it into the second O2 sensor wiring.
Old Jan 2, 2003 | 06:29 AM
mcbrown35's Avatar
Dou you tap into the wiring under the car or somewhere inside?
Old Jan 2, 2003 | 06:43 AM
under the hood, on the first cat that goes into the header.
Anyway, which one is first and which one is the second cat?
I always thought that the first cat is under the hood and the second cat is underneath, before the resonator (test pipe replaces second cat, right?)
Old Jan 2, 2003 | 07:02 AM
uranium9v's Avatar
right...first cat is in the header, second is before resonator. You wire the MIL right into the SECOND O2 sensor. What is does is send back a reading that all exhaust readings are ok regardless of what is really flowing thru the sensor.
Old Jan 2, 2003 | 04:06 PM
nightrider's Avatar
its coming from the exhaust i think. well my friend thinks its because of the different size of the pipes. since i am getting the turbo soon, i was wondering if i go to a muffler shop what size pipes i should get? and to pass emissions would i need to keep just the second cat?
Old Jan 2, 2003 | 04:25 PM
agsmooth84's Avatar
hows the performance increase with the header, i get mine soon
Old Jan 2, 2003 | 04:34 PM
nightrider's Avatar
i say prob as much as an intake.. i cant really tell but i do feel a little more power.
Old Jan 2, 2003 | 05:03 PM
agsmooth84's Avatar
what other mods do you have
Old Jan 2, 2003 | 06:33 PM
nightrider's Avatar
i have test pipe, rrm exhaust, injen cai, plug wires and i think thats it
Old Jan 2, 2003 | 09:42 PM
03RallyLancer's Avatar
hey i know this doesnt answer the question and all... but I was wondering bout the smoke coming out the exhaust??? a lot or none or what... was thinking bout the header and test pipe but with no cat, i was afraid there would be some really nasty smoke pouring out back there
Old Jan 2, 2003 | 10:11 PM
ROCK's Avatar
Normal stuff for a header. When you get your turbo in a week, noise will go away. It will quiet down and go a lot faster!!!
ROAD/RACE
http://www.roadracemotorsports.com/
http://www.carbontrix.com/
