fuse help..
Old Jan 20, 2003 | 10:22 PM
cleofis's Avatar
Exclamation fuse help..
k..so here's how the story goes..
once upon a night i was messing with my a/c control lights and i sorta plugged the little light in while the light switch was ON. i gave a soundless jolt. and now my lights barely light up. i'm thinking/hoping it was the fuse, but i cant find where the fuse for that is. i've searching the owner's manual, but it doesnt really speicify which fuse is for that area of lighting. any help?
Old Jan 20, 2003 | 10:24 PM
ocOZkid's Avatar
Just start checking the fuses under the hood and above and to the left of your feet, but I doubt that's your problem seeing as some light is still there.
Old Jan 20, 2003 | 10:26 PM
jabrien00's Avatar
I hope you didn't fry your wires them wires cost a lot
Old Jan 20, 2003 | 10:53 PM
cleofis's Avatar
i hope i didn't either..but the fuse is there so that you don't fry your wires..so i think it's jsut a fuse.
and damn!! those fuses are so hard to get out and theres so many...
Old Jan 20, 2003 | 11:09 PM
nightrider's Avatar
well there is the clip that is there to help you get them out.
Old Jan 20, 2003 | 11:12 PM
bobaab's Avatar
just use tweezers or soemthin..
-Bob
Old Jan 20, 2003 | 11:20 PM
azyan's Avatar
i blew my cig lighter fuse, there was a spark when it blew. no damage to the wire. but in his case, the light is dim. that mean his fuse still work. might wanna try replacing the mini light.
Old Jan 20, 2003 | 11:29 PM
andenbre's Avatar
https://www.evolutionm.net/models/la...irediag.php?s=
Old Jan 21, 2003 | 04:11 PM
cleofis's Avatar
how did you blow it? cause i checked my fuses and they all seem to be in tact. it might be the bulbs, but all of htem don't show light(very faint if any)..and by all i mean the 2 for the a/c controls and the cig lighter light..
Old Jan 21, 2003 | 08:56 PM
cleofis's Avatar
i might take my car down to mistu. tomorrow, but i doubt any of this will be covered under warranty..
someone help me!! ::desperate pleas::
Old Jan 21, 2003 | 09:00 PM
zlancer's Avatar
did you check the fuses under the hood? check them all...
also make sure your dimmer is not all the way down...
if its all the way up and the those a/c lights and cig lighter light is still dim and your gauges are bright you might have fried the wire that controlls the brightness of the bulbs for the a/c and cig lighter
