RRM piggy Ver.1
RRM piggy Ver.1
So I picked one up today. I'm the 3rd owner.
Anyway, I don’t think I have all the parts. Actually all I have is the Piggy, which has 5 cables and a vacuum tube. The install instructions speak of an additional vacuum line that routes from the piggy to the IM and T's off with the FPR. So I'm guessing that I need to pickup some tubing (dunno how long) and a T-connector for the tubing.
If that is correct, is there a specific type of tubing that is required. Also how long of a piece should I get?
Thanks for the help!
-J
-J
OK, so I went to AutoZone, and installed the vacuum tube. GREAT. So then I start to install the wiring for the piggy. I get to step #10. And I quote:
Well on my ECU there is NO pin 90. There is a WHITE/RED wire on pin 92. But the actual pin 90 is empty, according to my pinout picture.
I called RRM but nobody was there that could help. They told me to call back at 4:30pm. Anybody know which wire is the correct one to use?
Thanks.
"Cut the WHITE/RED wire on ECU pin 90. (Leave enough wire on both sides so that you can re-connect to both sides."
Thanks.
Not sure if it makes a difference, but I have a 03 OZ
So for the RRM Piggy:
RRM - - - - - > ECU
RED - - - - - > rd/y ig power
BLACK - - - - - > blk ground
Yellow/Black - - - - - > grn rpm signl
Green- - - - - > wht/rd airflow singal to ECU
Violet - - - - - > wht/rd airflow singal away ECU
Correct?
RRM - - - - - > ECU
Correct?
