electrical problems
Old May 2, 2007 | 06:03 PM
clutcher1983's Avatar
electrical problems
so i was sitting in my car the other day and i was just sittin in the parkinlot and i put the window down and like right after it got all the way down the guages all died, the turn signals don't work and none of my windows will work. so my drivers side window is stuck down and the others won't go down. i checked all the fuses and there all fine. i checked all the relays in the engine compartment fuse box and the fuse box under the dash on the drivers side and there not the problem. so i was wondering are there anyother relays like maybe in the door panel or anywhere else that would cause all this to stop working at once or what else could be wrong?
thanks
Old May 8, 2007 | 12:43 PM
lancerrally45's Avatar
Check all your fuses again. it never hurts to look twice. if they are all good. you may have a short somewhere. find something that went out and hook up a meter to it and see if you have power. if you dont, trace it to where u find the problem
Old May 9, 2007 | 01:17 PM
so i got the electricl problem fixed, well mostly, the gauges work and window but i gotta mis fire. the obd 2 reader says its in cylinder #2. changed the coil park, spark plugs, and still the mis-fire continues. would a bad ground to another component cause the misfire? everything else works just fine.
Old May 9, 2007 | 01:47 PM
u change the wires?
and what was the electrical problem from before, that you fixed?
Old May 18, 2007 | 05:01 PM
the electrical problem was a cut wire. the sri intake shield was rubbing agianst a wire and rubbed thru it. so my dad actually sauidered that back together for me. but still i got the misfire. replaced plugs, coilpack and wires. it has dual port injection which is famious for ****in up. alot of my dads friends are sure its one of the port injectors ****in up. stupid fuel saving economy design. itd be sweet if it was reliable. so i ordered a new injector today, should be here tuesday. any other ideas?
Old May 18, 2007 | 09:10 PM
03_Lancer_ES's Avatar
Immobilizer?
