RRM Piggyback with worse MPG
Old Jul 8, 2007 | 02:48 PM
Kamikaze978's Avatar
I just finished installing a RRM piggyback on my 05 OZ Lancer, made sure all wire were correcly attatched and connected. Followed all procedures and new get about 5 MPG worse even though I was told it would better my MPG. The engine also runs when it is just idle up about 500 RPM's. So I guess my question is can the piggyback be reset by unplugging and reinstalled and will this help?
Old Jul 8, 2007 | 02:58 PM
ambystom01's Avatar
Are you on the gas more often? I have no idea what this "The engine also runs when it is just idle up about 500 RPM's." means.
Old Jul 9, 2007 | 01:15 AM
iFeLLdOwN's Avatar
I think he means it idles at 500rpm instead of dying. How long has it been on your car?
Old Jul 9, 2007 | 01:33 AM
lytleflo's Avatar
i think he means its its idling higher than it used to!!!
i believe u have to get it reflashed, but that might not be the problem!
check all your hoses for any vacuum leaks (thats what happened to mine, check the ones on the throttle body those were the ones that were crack)...did u zip tie the hoses where u T-ed into the FPR???
Old Jul 9, 2007 | 09:59 AM
iufan4lifeul's Avatar
did you solder the wires??
Old Jul 9, 2007 | 10:59 AM
Noe18's Avatar
i should be gettin be piggy this week is it better just to buy a t clip so i wont have to cut anything nor solder, does any1 feel the diff in power
Old Jul 9, 2007 | 11:59 AM
lytleflo's Avatar
RRM recommends soldering!!! because the wires are too thin to splice with one of those clips, u could try but they sometimes dont work...and u really feel the difference right away, i felt it more around 4k rpm, but u also notce it when u shift!
Old Jul 9, 2007 | 12:07 PM
Noe18's Avatar
i have a auto, would i feel it when it hits last gear
