a/c help
Old Aug 8, 2007 | 07:11 PM
lancerrally45's Avatar
one fan should run most of the time while the other fan kicks on when the a/c is turned on. what kind of mods do you have? and how do you know its getting "freaking hott" other then by feel? you happen to have any gauges?
Old Aug 8, 2007 | 10:39 PM
02-Lancer-Es's Avatar
Originally Posted by denver
I have an '03 lancer Oz. My A/C works really well when its like 83 deg or less out side, if it gets like today 99 deg it works fine for a few min. then cuts out. Any Ideas?? I have charged it and it helps slightly but doesnt solve the problem. My thought was that it could be that controller by the fan....... I dont know. Also, there was a recall I think having to do with the fans, but I haven't ever had that done. Is it possible that the two are connected?? I have checked and when the A/C is "on" both fans are on, but the clutch on the Compressor is not engaged. Is that controller monted to the fan a part of the A/C system? Any Help, suggestions would be great, ITS FREAKING HOT!!!
same prob my sisters lancer has, its not the fan controller becuz i took of mine (ac works great) and put it on hers and it was still not working right
Old Aug 9, 2007 | 01:16 PM
denver's Avatar
What I ment by its getting "freaking hott" is me driving around with no A/C its hot here in texas!
The fans work as they are intended to orginally. The car is bone stock.... When the A/C is turned on the A/C fan kicks in every time, but the clutch on the compressor does not engage. I drove to work this morning and the outside temperature was in the mid 80's and my A/C on my car was putting out cold 60 deg (estimate) air. But this afternoon when I go home it will be 95 deg + outside and my A/C will work for about 5 to 10 min then shut off......... I have no idea why, all systems seem to work right, the car is not over heating, the both fans run.........
Old Aug 17, 2007 | 12:39 PM
eyekyu's Avatar
sa town, any luck with your sis a/c?
i had mine checked for leaks and no leaks. my a/c still blows warm & cold over 2000RPM
anyoone else have any ideas
Old Aug 17, 2007 | 04:14 PM
nope no luck but she really hasnt done anything about it she's lazy , but sound to me like ur compressor might be slipping have u checked ur belts ? or the belts may b loose
Old Aug 17, 2007 | 04:19 PM
eyekyu's Avatar
the compressor can slip hmmm yeh my belts are tight but its weird when my a/c is on and while im driving i heard this weird noise and feel it in my gas pedal?????
Old Aug 17, 2007 | 04:27 PM
oh i dunno about that but if u hear a noise and can feel it there probably slipping check them to c if there worn out becuz thats was my alternator used to do
Old Sep 27, 2007 | 01:14 PM
Fixed.....cost 20 bux
Old Sep 23, 2009 | 11:25 AM
Lunchb0x's Avatar
What was the fix? that cost 20 dollars?
Old Sep 23, 2009 | 02:18 PM
Yea it was a sensor behind the Ecu behind the glovebox !
KillaYayo
Aug 31, 2016 10:47 AM
kd5byb
Lancer Troubleshooting
Sep 7, 2013 05:44 AM
nile13
Jul 31, 2013 12:14 PM
kRAKA_P
Jul 12, 2012 05:21 AM
MagnumVP
Lancer Engine Tech
Jul 19, 2011 08:47 PM
