car shivers
Old May 9, 2008 | 08:09 PM
Nirvash's Avatar
car shivers
For a few days now my car has been shaking when the car is idle. i can also see the RPM's fluctuating a bit while in idle. what do you guys think the problem?
could it be because of wiring? i just installed glow gauges on the car.
Old May 12, 2008 | 03:06 PM
mcgarvey's Avatar
Misfire or vacuum leak. Start by replacing plugs and wires and testing coils.
Any codes?
Old May 12, 2008 | 05:11 PM
bcollinstex's Avatar
Ditto, check the vacuum system, PCV valve.
Also, if you haven't done it, use a fuel system cleaner. And it may be worth it to do a run through with Sea Foam.
Old May 12, 2008 | 11:21 PM
Nirvash's Avatar
mmmmmmmmm, does the vacuum system actually sound like a regular house vacuum if there is a leak? because i've been under the hood a few times while the engine was running and heard something that sounded like that.
how do i check if there is a leak?
is it possible to fix by myself?
