my car died on the freeway
Old May 11, 2008 | 02:29 AM
ILovE WHEELS's Avatar
so heres the story,
i was on the freeway cruisin at about 70 then out of no where my car shuts down.
i lost all engine power.
full tank of gas.
i still have power to everthing else like radio,lights,windows,etc.
car turns over but wont start.
checked fuses and sorts.
there is no oil leaking, or anything rattling or sound broken.
and my engine is all stock at the moment as in intake, exhaust, etc.
im lost at the moment as far as whats wrong,
fuel,spark,fuel pump...dunno open for any help
thanks
Old May 11, 2008 | 09:50 AM
Fujiv99's Avatar
timing belt borke?
Old May 11, 2008 | 11:24 AM
yellance's Avatar
hmmmm do you have an intake cause that can come loose and cause those very symptoms and i would check your battery too
Old May 11, 2008 | 11:40 AM
im running stock intake, and my battery is just fine bc my stereo works just fine and lights n all. i just took off my timing cover to look at the belt.
looks fine but i noticed that all my other belts turn when cranking it over except my cam gear and timing belt......
is that normal bc i dont remember that happening w my old car???
or are all my belts still supposto move anyways.
Old May 11, 2008 | 10:43 PM
senate6268's Avatar
That would mean that your timing belt snapped. Sorry...
Old May 12, 2008 | 03:44 AM
took it apart yesterday figured out the problem
Old May 12, 2008 | 03:53 AM
lancerrally45's Avatar
how bad is it?
Old May 12, 2008 | 04:16 AM
sharkm87's Avatar
you know we will ask.....what was the problem
Old May 12, 2008 | 01:27 PM
johnd651's Avatar
Old Jun 8, 2008 | 06:23 PM
EdT's Avatar
EdT
Proberly a dirty crankshaft sensor, this is a known issue with 02-03 Lancers.
Old Jun 8, 2008 | 07:04 PM
クリス's Avatar
If the timing belt wouldn't move when cranking, but the other belts would, that sounds like a serious problem. A problem that involves 16 valves, quite a bit of heat, and collision with the pistons lol.
Old Jun 8, 2008 | 07:34 PM
kungfugirl's Avatar
terrible news.
Old Jun 8, 2008 | 07:39 PM
Walkingchaos's Avatar
what was the issue ?
Old Jun 15, 2008 | 08:37 PM
forgot about this thread...well my timing belt some what broke...a few of the teeth broke off causing my timing to go off thus makin my car turn off. end result: all of my exhaust valves needed replacement. so its fixed now and running though.
Old Jun 15, 2008 | 10:52 PM
oakley198877's Avatar
damn... that's why changing the timing blet is so important... at least you got it fixed and it's running~
