Turn Signals
Old Sep 10, 2002 | 06:04 AM
Jizzay1's Avatar
Legality of this all
What are the legal limits to changing your light bulbs?
Old Sep 10, 2002 | 11:51 PM
NeX's Avatar
NeX
aheh.......
Turn signals must be ambered colors, or close, pure hyper turn signals will get you expensive tickets.
owners manual has not told me one usefull bit of information on how to change lights or even part numbers
Someone mentioned early that they just forced the blinker bulb in by shafing the nipple explain to me in more detail???
Old Sep 10, 2002 | 11:54 PM
Pimpson's Avatar
shaving nipples? come on Men grow up, this isn't some damn Pink Floyd video.
Old Sep 10, 2002 | 11:56 PM
wags528's Avatar
do not force anything into anywhere - - - the manual does have the sizes of the bulbs in it and how to change them - - - the turn signals are PY21W . . . ?? I believe from memory and to change them is so simple - - - turn and pull out the bulb assembly . . pull out the bulb and put in the new one - - put the bulb assembly back in . . . EASY AS THAT - - if u try to force in bulbs that were not made to fit you run the risk oh shorting something out or completely f***ing up your lights . . . . .
Old Sep 10, 2002 | 11:58 PM
wags528's Avatar
Originally posted by schmeckp
They're as they say on the bulb and in the manual - PY21W - they've common in many european cars, and one place I found them was at autolamps-online
They have Philips Silver Vision - silver when off, amber when on. Note, both front and rear signals are the same bulb...they're $24/pair shipped.
+schmeckp
exactly like this . . . . .
Pimpson's Avatar
for the driver side turn signal, is it necessary to remove the battery? there sure isn't much room on that side.
Old Sep 11, 2002 | 01:29 AM
LancerXtreme's Avatar
I ordered my Front and Rear Turning and Interior Dome Lights from RAIautosalon.com in Super White. I should get them tommorrow according to UPS. I'll keep everyone posted as to how they fit. I hope it fits well for the $73.95 that I paid for them. And if they do.....Then thats money well spent
Old Sep 11, 2002 | 01:35 AM
DJPhattRoc's Avatar
xtreme how hard was the RRM TB to put on.....also can u feel a difference? post back please
Old Sep 11, 2002 | 02:15 AM
wags528's Avatar
no (unless you have monster hands ) you dont have to take out the battery - i changed out my front and rear turn signals with sylvania silverstars in less than 15 minutes!
Old Sep 11, 2002 | 03:34 AM
Pimpson's Avatar
the lord blessed us germans with meaty palms and stubby fingers...but if you say it can be done i'm sure it can be done. thx
Old Sep 11, 2002 | 08:54 PM
PhatLancerOZ's Avatar
2002oz you have to take off the clips by the wheelwell in the front and you slide your hand through there to get teh bulbs! dont take off the side markers cause they are glued on there!!! i hope you didnt do that
Old Sep 11, 2002 | 08:55 PM
2002oz you have to take off the clips by the wheelwell in the front and you slide your hand through there to get the bulbs! dont take off the side markers cause they are glued on there!!! i hope you didnt do that
Old Sep 11, 2002 | 08:56 PM
all my bulbs are hyperwhite, it was about 70 bucks all together for all the bulbs. it looks hot!!
Old Sep 11, 2002 | 09:16 PM
wags528's Avatar
my sidemarkers were not glued on?? - - just popped them out replaced the bulb and popped them back in - - you would never know that i ever took them off
Old Sep 11, 2002 | 10:01 PM
mcbrown35's Avatar
I used the APC Hyper white bulbs for my side markers, front and rear turn signals. (I also removed my rear license plate lights)They look blue when not on and white when on. Be carfeful when removing the side markers as my lens seperated from the housing. I had to use super glue to reattach it. I used a vice to squish one of the nipples in on one side of the bulb. It worked fine on all four bulbs.
