RRM SRI problem
Old Sep 10, 2008 | 08:20 AM
nikkimiao128's Avatar
RRM SRI problem
so the other day i got a RRM intake.. and me and my frds installed it.. after driving it for a day.. the engine check light appeared.. has this happened to anone b4?.. or is it just my intake?.. what should i do?
Old Sep 10, 2008 | 09:35 AM
EngRWW33's Avatar
Check for leaks and check the MAF sensor. If nothing really sticks out to you, take it off and see what happens with the light... calling rrm would probably be helpful as well
Old Sep 10, 2008 | 05:11 PM
Bawb3's Avatar
Did you use the MAF O-ring and Allen screws that came with the intake? Make sure its seated level on the housing and secured snugly. And make sure the sensor cable is plugged in firmly as well. If those don't work, I'd give RRM a call and see if they can help, you could have received a faulty intake. The MAF sensors in these new cars can be very sensitive.
Old Sep 11, 2008 | 08:23 AM
evo_soul's Avatar
bawb is right, always call RRM first. Second, the sensor is very very sensitive, as was said as well.
I am in Toronto, we can meet up somewhere and use my scan tool to pull the code, it will give RRM a better idea of where the problems is.
Old Oct 23, 2008 | 12:36 AM
reldas's Avatar
i was driving the other day, and i got the header and intake installed. and all of a sudden my car jolted and the check engine light came on and it said requires service. so i poped the hood and unplugged the intake sensor and put it back in and everything was ok. but has anyone had that happen were the car did that?
