Plz help with small electrical problems
Old Nov 13, 2008 | 03:50 PM
mitsu fan's Avatar
The small parking lights in both of my headlights do not work. The front cigarette lighter (the one by the ash tray) doesn't work as well. I have checked for bad fuses and have not found any bad fuses. Any ideas?
Thanks!
Old Nov 14, 2008 | 03:53 AM
kalpakiotis's Avatar
Have you put in any aftermarket parts? If you havn't done anything to the car, bring it to the dealer. It could be as simple as a bad ground connection, or something else.
Old Nov 18, 2008 | 07:57 AM
CamShaft's Avatar
have you checked the bulbs?
Old Dec 21, 2008 | 05:57 PM
TRASHY_GTS's Avatar
I've already had to replace two fog light bulbs, one parking light bulb, left side headlight and wiring harness, horn fuse, and now one of my licence plate bulbs comes on and off.
Old Dec 22, 2008 | 08:56 AM
homieG's Avatar
wow......soemthing is def causing it to blow....i woudl put everythign back to stock and get that stuff looked at by the dealer. before u blow more stuff on ur car. lol
Old Dec 23, 2008 | 09:47 AM
CamShaft's Avatar
Light and bulbs are covered under warranty for two years you know.
Old Dec 23, 2008 | 10:02 AM
NJ08LancerGTS's Avatar
when you turn on your car do the revs go all the way up silently and come back down and reset? i had a similar issue with my eclipse.
Old Dec 23, 2008 | 12:23 PM
Elvis077's Avatar
Unless the wiring has been altered. Then your out of luck.
