engine squeeling
Old May 4, 2009 | 09:19 AM
Noe18's Avatar
engine squealing
i have a 03 lancer es and just had my timing belt changed and water pump, had squeeling before but thought it was my timing belt . It only does it when it gets wet under carriage, now its happening all the time when its raining does anyone has this prob please help, can it be other belts??
Old May 4, 2009 | 10:06 AM
blaze_125's Avatar
serpentine belt.
It goes around pretty much every single pully that's on the left side of your engine when you look at it standing in front of your car.
Old May 4, 2009 | 10:10 AM
Noe18's Avatar
thats the larges belt correct??, when this gets replace it should be ok am i right, maybe it has to be tighted
Old May 4, 2009 | 10:24 AM
blaze_125's Avatar
Look at the belt and check if it does need to be changed or not.
Check if it's cracked or about to snap or whatever
Your belt could still be good and it may just need an ajustement. It could currently be too tight, or too loose. Play with the alternator tensioner bolt to loosen, or tighten.
Old May 4, 2009 | 10:28 AM
Noe18's Avatar
thanks
Old May 4, 2009 | 10:41 AM
blaze_125's Avatar
thanks
Anytime
And keep us posted.
Old May 8, 2009 | 01:09 PM
naniekso's Avatar
mine does that too, not only in the rain anymore.
every time i turn on my car in the morning it squeels for about 2 secconds.
Old May 8, 2009 | 04:24 PM
Ozdriver's Avatar
if it was recently changed you may have to adjust the tension on it a little because the belt will stretch a little bit as it gets "broken in"
Old May 8, 2009 | 04:29 PM
03_Lancer_ES's Avatar
It may also do that if you're accelerating in a higher gear.
Old May 10, 2009 | 07:27 AM
Noe18's Avatar
i checked and yea it alittle to tight
Old May 17, 2009 | 08:31 AM
Noe18's Avatar
ok, guys i loosened it a little but still the same, but i kept searching where is coming from and its from the alternator, buts this sounds right can alternator squeal???, if its true where can i get a good alternator standard 90amp can go a little higher
Old May 17, 2009 | 05:24 PM
Noe18's Avatar
ok guys just found out what it was, i think is call the v belt, its the belt that goes around the alternator, have to replace it, i put some lubricant on it and it when away for a min
Old Jun 1, 2009 | 08:04 AM
xisien's Avatar
You know mine is doing that same exact thing, at first I thought it was coming from the alternator as I had the voltage checked and it was getting low voltage, so I changed out the alternator.. noise still there. Well my car battery is drained after sitting for about 4 hours, have had everything tested good battery etc... went far as swapping the battery in it for another as I have had bad batteries show good. Wonder if the belt could be affecting the charging of battery? Have/did you have any problems with your car not getting the juice it needs? Have you noticed anything else along with this?
My thread is here about this:
https://www.evolutionm.net/forums/la...ple-hours.html
