Need help fast!
Old Jul 1, 2009 | 11:00 PM
yitzac1990's Avatar
Need help fast!
Ok, so I was rearranging some stuff around under my hood today, mainly electrical, and I noticed that on the positive wire fuse block (attached to the battery), there are 4 fused spots, but only 3 of them are being used. I have a GTS with no packages (so no RF system, sunroof, etc.) I just want to know if only 3 wires are correct, or if somehow the other one came off. I definitely did NOT take it off, so I think its normal like this, but I want to double check.
Thanks!!
Old Jul 2, 2009 | 05:34 AM
kalpakiotis's Avatar
its normal....i have all the nav with sunroof and that spot is still open.
Old Jul 2, 2009 | 08:26 AM
yitzac1990's Avatar
awesome thank you very much! Also, I noticed something else. if looking at the battery from the front of the car, the spot between the 2 LEFT connections on that block seems like it blew (theres a small gap between 2 pieces of metal). is this also normal?
Old Jul 5, 2009 | 07:01 PM
not sure what your talkin about, if u can take a pic that would hlp
